Hi there,
yes. I installed and LED from Vision X. through Vsioionx wholesale.
Installed a Soltice prime solo 10w very bright and small that only draws 0.83 amp. (got the 20 degrees beam, maybe 10 degrees could be better to see more far ahead, but still is really good).
installed a dedicated on/off switch with a harness to the battery.
with a "y" connection to have a regular colored led to indicate when my LED light is on. (before adding the extra indicator led, left my auxiliary led light on).
attached to the lower fork clamp with a home made bracket just under the headlights
really nice to use at night, in the fog, and as day running light.
