Originally Posted by Wayne's Striple
Best to always use tight fitting ear-plugs with ANY loud high-mount exhaust (the wind noise reduction is a bonus). Helmets tend to amplify the sound way louder than the pipes really are, especially below 6000 rpm, because the pipes are right behind you. Keep the revs low until you are away from urban areas to avoid the attention of police. The 20589 tune (new TORS) works nicely with the Dans and always install the baffles (tap them in on the inlet side with a hammer and large socket). At least if one does not like the loud high-mount exhaust you won't be out a sh*t load of money with the Dans. Mine are two years old and still solid like new. - Wayne
I've been using ear plugs and they sound beautiful with the earplugs in. However the annoying thing is I keep forgetting to plug them in before I strap the helmet plus I can't use my helmet bluetooth handsfree.
In regards to the TOR map, what are the benefits of remapping? I've read its to make the mixture richer because there's less back pressure, if so does that means it will use more fuel?
