Originally Posted by DCLXVI
Now Im concerned! Approx. 160lbs, but how can you tell if suspension adjustments are needed?
You really answered this in your own original post: "As far as I perceive it, the bike seems to handle very well. 'If it ain't broke, don't fix it'."
You're within the target weight range for the average setting, so if it's handling well and you aren't experiencing any less than satisfactory results, then why fret yourself over it?
If you just can't help obsessing when you see mention of suspension adjustment on the Internet, though, then refer to the little R-specific insert that should have come with your owners manual. Setting numbers from that insert have previously been posted by member Djm in another thread on this forum. Here it is again:
...............Rebound (F)...Compression (F)...Rebound (R)...Compression (R)
Standard............4...............4...............8...............8
Softer..............6...............6..............10..............10
Sport...............2...............2...............6...............6
2up.................4...............4...............8...............8
The front spring pre-load should always be at 7 turns out for all settings.
But I must remind you that despite the casualness with which some folks tinker with preload, Triumph specifically warns that it is NOT a user adjustment, and this site does not endorse going contrary to any manufacturer's explicit safety warnings. If you talk yourself into believing it might need adjustment, I suggest having that part done at the shop.
