Electrical Accessory Wiring Harness - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 11-17-2009, 11:18 AM   #1 (permalink)
Favourite Bike: 2009 Street Triple R
I just purchased some Tourmaster heated gear and when I went to hook up the wiring harness to the battery, I discovered something...It's already there :-)
I didn't see anything in the Triumph manual about the bike being wired for accessories, so I'm wondering if my dealer wired it for a battery tender, and then forgot to remove the harness. The plug outlet is tie wrapped just underneath the Triple R plastic on the left side of the bike. Its in the perfect position for hooking up my heated vest.
Is that a dealer installed "option", or did they just forget to mention it in the manual?
targetdude is offline   Reply With Quote
Old 11-17-2009, 11:52 AM   #2 (permalink)
Could you please post up a picture of this plug and it's location? Other than the connector for the alarm and code reader tool, I was unaware of any other accessory plug on the bike.
Neanderthal is offline   Reply With Quote
Old 11-17-2009, 02:19 PM   #3 (permalink)
I'll try to take photos of it tonight. I found it by following an extra set of wires that were attached to the battery. The harness had a 25 amp fuse on it and ran from the box behind the battery along the left hand side of the frame.
Old 11-17-2009, 07:41 PM   #4 (permalink)
Photos
Neanderthal,
Here are the photos...hopefully :-)
I'm beginning to suspect that the dealership put it on for a battery tender and just forgot to remove it when I bought the bike. Either way, now I have a spare harness in case something happens to the original one. Let me know if you find one on your bike.
Electrical Accessory Wiring Harness-s7301176.jpg   Electrical Accessory Wiring Harness-s7301177.jpg
Old 11-17-2009, 11:18 PM   #5 (permalink)
Mine has a different connector but the same wiring. They wired up a connector for a battery tender and left it on when I bought the bike. Cool gesture in my opinion.
2-wheel-wannabe is offline   Reply With Quote
Old 11-17-2009, 11:26 PM   #6 (permalink)
Well, that's not a pigtail from the original "Battery Tender" made by Deltran (an SAE type plug), but it could be Triumph's or some other battery tender-type product. That type of plug is more commonly seen with heated clothing. Thanks for the photos though. Mine did not come with a loose feed. I did hardwire a Deltran Battery Tender Jr in place after running my battery down, twice, lol. Took me a little while to quit turning the key all the way to the left.
Old 11-18-2009, 01:16 AM   #7 (permalink)
Favourite Bike: Street Triple R
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
Mind came with a battery tender pig tail on the battery as well. Not the type you had but the old type.
MacBandit is offline   Reply With Quote
Wiring Harness Help. cbm206 Classic, Vintage & Veteran 3 09-26-2008 06:45 PM
I Need Wiring Harness Help JEB Twins Talk 12 03-05-2007 11:01 AM
Wiring Harness tuffy22 Trophy 3 09-05-2006 06:17 AM
Wiring harness RacingGreen T3 Sport / Touring Forum 6 01-11-2006 10:50 AM
Headlight wiring harness electrical tape? humble The Rocket Science Forum 2 11-25-2005 11:38 AM
