Oil on my front rotor RH side: - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Motorcycle.com Classifieds!Ontario Tourism
Old 11-15-2009, 04:59 AM   #1 (permalink)
Favourite Bike: 09 Street Triple
Other Motorcycle: 06 Husqvarna SM 610
Extra Motorcycle: Hyosung GT 250
I noticed oil running down my rotor and a little pool on the rim edge. There is also oil on the outside edge of the rotor all the way around, mixed with brake dust and I can't find where it's coming from. I can't find a leak anywhere and it's not near the caliper. It's more toward where the fork comes down. Could it be coming from my fork?? I stuck my finger up inside the fork and it was wet in there. Anybody got any thoughts about this?
thx
electric gypsy is offline   Reply With Quote
Old 11-15-2009, 08:44 AM   #2 (permalink)
Favourite Bike: Street Triple R
Lucid Triple's Avatar
Other Motorcycle: 82 Honda Nighthawk 650
sounds like a fork seal, but I would think it would run down from the outside
it's not someones pet doing it's thing on your wheel is it
Lucid Triple is offline   Reply With Quote
Old 11-15-2009, 02:37 PM   #3 (permalink)
oil on my front rotor RH side
I was wish it was just the neighbors mutt. I'm gonna ride it without using the front brake and see if I can find it by process of elimination.
Old 11-15-2009, 04:49 PM   #4 (permalink)
I narrowed it down to the right front fork. It's leaking under the fork below where the axle goes through. There's about a 1/2" inside diam hole at the bottom of the tube and it's dripping to the ground and onto the rotor when it's parked on the side stand. The liquid is clear. Does anyone know how big a job it is to reseal the fork? I'm sure Triumph will stick it to you.
Old 11-15-2009, 06:30 PM   #5 (permalink)
SFstreettriple's Avatar
Pricing in California is about $175 for new seals and oil with the forks on the bike.
SFstreettriple is offline   Reply With Quote
Old 11-15-2009, 06:37 PM   #6 (permalink)
oh should have mentioned, keep that oil off your break pads or they will be ruined and not to mention unsafe!
Old 11-15-2009, 08:23 PM   #7 (permalink)
Thx SF,
Does that include the labor? I think it's too late for the pads. Before I noticed the leak, they were soaked.
Old 11-15-2009, 10:38 PM   #8 (permalink)
Yep, that's what I was quoted for parts and labor.
Old 11-16-2009, 12:02 AM   #9 (permalink)
I don't know how the upside down forks work. The oil is coming down (I think) from the inside. It seems to be dripping around the axle. The outside of the fork is dry. Thx for the info.
Old 11-16-2009, 12:50 AM   #10 (permalink)
Thumbs up
I think you may have lost #15 & #16 from the bottom of your tube;
iconhttp://www.bikebandit.com/2008-trium...17742sch570638
check it out, see if you can get a mirror on the floor to look up into the tube (flashlight would help too)
Front Rotor Bolts Big Wig Speed Triple Forum 2 09-22-2008 04:46 PM
Front Rotor Adventure96 Hinckley Classic Triples 6 08-23-2008 02:55 PM
front rotor pulse jenglandtoyman Hinckley Classic Triples 6 01-21-2007 01:29 AM
S4 Front Rotor compatibility SoCalS4 Triumph SuperSports 3 11-01-2006 07:56 PM
Front brake rotor mmelgar Maintenance & Workshop Talk 2 09-10-2005 02:23 PM
