low voltage issue - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGearNew Bonneville
Old 11-12-2009, 12:22 AM   #1 (permalink)
Favourite Bike: Street Triple R
dallasStreet's Avatar
low voltage issue
Hi, I was wondering if anybody can shed some light on a problem i've recnetly had.
Bike: St3R with a "triumph" alarm delivered 3 months ago. T
The first 2 and half months i had it back witht the dealer four times due to a problem with the alarm. they repalced the alarm on the fourth time
for 6 weeks everything was great. then on tuesday 10/nov the bike wouldn't start. Turned out to be low voltage on the battery.
The dealer said everything was normal, battery was fine, the alarm was fine and the charging system in the bike was fine as well. I just need to get a charger and charge it every two days.
I ride to work every day (5 days) about 22k each way, fast and slow traffic, i keep it above 4k most of the time.
So is it normal ? anybody else had problems like this ? Should i need a charger ?
dallasStreet is offline   Reply With Quote
Old 11-12-2009, 01:43 AM   #2 (permalink)
Ducken's Avatar
If this was your usual Japanese bike, no, it would not be normal. I'll leave it to the Triumph experts to say if it is normal for a Street Triple. I've been through this with the Honda VFR 98-01, and have heard the Street Triple has a weak charging system. Do you (or anyone else) know how much current the alarm system draws when the bike is off?
I'm sure others besides myself will be watching this thread closely, please keep us informed of any progress with your dealer/Triumph. Ken
Ducken is offline   Reply With Quote
Old 11-12-2009, 10:35 AM   #3 (permalink)
Lucid Triple's Avatar
Other Motorcycle: 82 Honda Nighthawk 650
how long between starts anyway that's not normal, anyway if the dealer isn't so helpful i'd put the battery on a tender instead of a charger
Lucid Triple is offline   Reply With Quote
Old 11-12-2009, 11:09 AM   #4 (permalink)
Favourite Bike: 2009 Street Triple R
Pokeyjoe's Avatar
Do you have a multimeter? If so, measure the voltage when the bike is running at idle and at about 2K RPM.
John
3-7-77
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is offline   Reply With Quote
Old 11-12-2009, 08:03 PM   #5 (permalink)
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
That's less than 14 miles each way which is bare minimum to recharge a battery after the draw created by the starter on start up. If you had a 600 watt alternator then it would probably be okay but would still likely wear the battery down over time creating premature failure on the battery. Also keep in mind that running with a depleted charging system creates undue stress on the charging system and can cause premature failure. I've seen this sort of problem on multiple bikes over multiple brands so this is definitely not singularly a Triumph problem. It depends mainly on the peak output of the charging system less the draw the bike has just in order to run the main systems. The Street tends to have more draw then the Daytona because it runs both headlight all of the time and the Daytona has all kinds of charging problems on it's own so you can see where that's going. Yes, the charging system on the 675 could be called anemic but it's not alone in the sport bike or motorcycle world in general.
How ever.... That said, 2 days from full charge to the point of being depleted enough to prevent start up is excessive. If you are indeed saying that charging the bike over night results in that you can ride for 2 days before it will not start without a charger then you indeed have an issue.
MacBandit is offline   Reply With Quote
Old 11-23-2009, 06:58 PM   #6 (permalink)
Update.
The dealer had a chat to triumph in Melbourne and they said the issue could be a battery related. The battery voltage drops to 11.15V whilst cranking this should only drop to 11.3V. They are going to replace the battery for me under warranty - hopefully that will be the last of my "D#mn bike wont start" problems
I should say the dealer has been very helpful and put a lot of effort into finding the problem. I'm very happy with their service
Old 11-24-2009, 10:16 AM   #7 (permalink)
jsobell's Avatar
So I guess the 5km (3miles) I do each way to the office and back every day means I should have been jump-starting mine for the last 6 months?
Twitchy
(did I mention that batteries never go flat in Australia? "God's country" as it's known over here!)
jsobell is offline   Reply With Quote
Old 11-24-2009, 01:46 PM   #8 (permalink)
MacBandit's Avatar
Yeah most motorcycles I know of even ones with larger capacity charging systems see battery decline with commutes as short as yours. Feel lucky.
Old 11-24-2009, 02:46 PM   #9 (permalink)
Pokeyjoe's Avatar
+1 - same commute distance.
John
3-7-77
Old 11-24-2009, 11:35 PM   #10 (permalink)
I'm definitely going to fork out the cash for a trickle charger. I don't have to stuff around getting the bike transported to the dealer and then wait a day to get her back - plus this should lengthen the life of the battery.
what should the voltage be at? RUSTSPOT Classic, Vintage & Veteran 8 07-22-2009 06:00 PM
Charge voltage CrazyChris Sprint Forum 53 11-28-2008 03:01 AM
voltage stone62 Classic, Vintage & Veteran 4 04-19-2008 05:46 PM
Voltage Readings 1050STrider Sprint Forum 1 11-24-2007 12:38 AM
what are your voltage readings??? Hozer Club Cafe' 3 09-02-2006 01:17 PM
