Battery died twice in one week! Now I know why. - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 10-31-2009, 08:20 PM   #1 (permalink)
iov9's Avatar
My usual commute is 112 miles round-trip, but for the last couple of weeks I've been housesitting about 15 minutes away from work in LA. At the end of the first week, I went to start it and nothing, battery was dead. Got it towed to a friend's shop. He charged mine overnight and I borrowed his battery. Everything was good to go. A week later, same thing. This time I just got a jump start and was able to ride it back home.
I was so upset because I thought I need a new battery. I found the cause of the battery drain after talking to a guy at a motorcycle shop and then did some research online. I thought I'd share it with you guys. Since I'm a newbie, I never would have known this would be a problem, but this is totally what happened to me riding for 15 minutes at a time in LA's surface street rush-hour traffic.
How do you ride the unit?
Short trips may not replenish the charge taken from the battery during normal engine starting. Frequent short distance riding may eventually discharge the battery. Short distance riders will also benefit from a battery trickle charger.
Do you mostly engage in prolonged in-town, low-speed operation?
If so, this type of operation, (consisting of low engine RPM, frequent brake light use, and frequent cooling fan cycles,) can also discharge the battery. Alternating gears (to raise engine RPM) will help. Remember to always turn the engine off using the ignition key. Leaving the lights on with the engine off is also a big "no-no."
Do you ride with the high beam headlights on?
Though it is recommended during the day for safety, high beam usage accompanied with the in-town riding mode described above, will change the discharge rate of your battery. Don't discontinue usage of your high beam, just be prepared for possible accelerated battery discharge by keeping the right tools around to serve your needs.
iov9 is offline   Reply With Quote
Old 10-31-2009, 09:05 PM   #2 (permalink)
Favourite Bike: 2009 Street Triple R
Pokeyjoe's Avatar
My commute is three (3) miles one way. Way less than fifteen minutes. I rarely get it over 6K RPMs. My battery is charging fine.
John
3-7-77
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is online now   Reply With Quote
Old 10-31-2009, 11:28 PM   #3 (permalink)
Favourite Bike: '06 ZX10R
Drainfade's Avatar
Other Motorcycle: '06 TTR50
Extra Motorcycle: Rossi replica model
An easy solution to the problem is just keep your revs over 4K and it'll stay charged. You can also install a voltmeter and see if you're charging or not and adjust your RPM's accordingly.
Drainfade is offline   Reply With Quote
Old 11-01-2009, 01:55 AM   #4 (permalink)
Diego's Avatar
Good points, iov9, most of which have been mentioned in previous battery related threads here. But the other guys are also correct. A couple of good 15 minute rides a day should be enough to keep the battery from going flat every week. Might be a good idea to have that charging system checked out.
(Also bear in mind that each time a battery gets too low, sulfation takes place that gradually reduces the amount of charge it can take. That will shorten its lifespan.)
John
Old 11-01-2009, 01:58 AM   #5 (permalink)
Mine goes on a battery tender jr if it's going to sit more than 3 days without a ride. Keeping a trickle charger plugged into any battery has been proven to prolong battery life (fights sulfation).
Neanderthal is offline   Reply With Quote
Old 11-01-2009, 04:19 AM   #6 (permalink)
In LA, a 15-minute commute is one mile.
CGameProgrammer is offline   Reply With Quote
Old 11-01-2009, 12:22 PM   #7 (permalink)
Diego's Avatar
Terminology alert: don't leave your motorcycle battery hooked to an ordinary trickle charger!
Those push a continuous current through the battery, regardless of its state of charge, and that will dry out the cells prematurely. The Battery Tender Jr and similar products are "smart" battery minders that sense the state of charge and cut off current when no further charging is needed.
John
Old 11-03-2009, 10:14 AM   #8 (permalink)
I would think there is another fault, battery maybe not holding charge? I know it's not the same, but I started a car that had a flat battery (boost pack) and it took 70amps at idle, I'm sure the st would put out enough to keep the battery happy at any speed
using a macbook pro,Street Triple and a 1958 Land Rover. (wife has a british built Honda)
Dickie2679 is offline   Reply With Quote
Old 11-03-2009, 11:02 AM   #9 (permalink)
Pokeyjoe's Avatar
Originally Posted by Dickie2679 View Post
...I'm sure the st would put out enough to keep the battery happy at any speed
Unfortunately, the 675 charging system is not what it could be. Lots of people have had batteries, rectifier/regulators, and stators fail.
John
3-7-77
Old 11-04-2009, 06:55 PM   #10 (permalink)
Favourite Bike: Triumph Speed Triple 2006
rnexussix's Avatar
haha !! So true.
On a serious note. I drive about 20 mins to work and that long back and the battery seems to be charging well.
rnexussix is offline   Reply With Quote
1st week of ownership, Battery dead after sitting for only two days - this sucks! keyser_soze Daytona Deliberations 5 07-25-2009 08:53 PM
What the.....? Battery died in 6 days McRuss Twins Technical Talk 10 05-17-2009 05:51 AM
My cat died last week..... Cynr1023 Biker Hang-Out 27 01-28-2008 04:22 PM
Battery Died Today Thefallenone Sprint Forum 3 12-24-2006 07:06 AM
Service engine light after battery died. t595 Maintenance & Workshop Talk 11 09-10-2004 12:13 PM
