I've got a Hinkley twin, so it's much easier to access the plugs, however, I could use some input from you all on this:
After washing my Bonnie on Sunday, I ran the engine for a few minutes afterwards. What I saw during that time was this:
My left side’s cylinder was “bubbling” a little where the water was – all around where the spark plug is seated. Also notable – the right side’s plug didn’t bubble at all.
I recently (a month ago) took the plugs out to check the gap and clean them, and I’m wondering if I should have replaced the “crush washer” on them then.
Should I drop a new set of plugs in? Or, just put some spark plug grease around the threads?
