Street Triple Down Shifting: - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearOntario TourismMotorcycle.com Classifieds!Honda Powersports
Old 10-05-2009, 03:43 AM   #1 (permalink)
Favourite Bike: 09 Street Triple
Other Motorcycle: 06 Husqvarna SM 610
Extra Motorcycle: Hyosung GT 250
Does anyone have a problem downshifting? I mean, if you get caught in 4th gear when the light's turning red, or if someone pulls out in front of you and you have to make a quick stop, do you have trouble getting down throught the gears? If I get stuck in 3rd or
4th, I can't seem to get down to 1st without letting the clutch out and pulling it in 3 times (not touching shift lever, the shift lever is all the way down) just letting the clutch out gently and I hear a loud click. On my other bike I can shift down 5, 4, 3, 2, 1, with no sweat, but no can do on the Street Triple. It upshifts fine.
electric gypsy is offline   Reply With Quote
Old 10-05-2009, 03:47 AM   #2 (permalink)
No bugs on the windshield
Old 10-05-2009, 08:30 AM   #3 (permalink)
Yup, I have that issue sometimes also. It's not really a big deal but it can be annoying sometimes!
alphamang is offline   Reply With Quote
Old 10-05-2009, 08:41 AM   #4 (permalink)
Favourite Bike: Street Triple R
Lucid Triple's Avatar
Other Motorcycle: 82 Honda Nighthawk 650
same here, I forgot to downshift when or before I was stopped and when the light turned green I stalled then had to fumble down through the gears, just have to make a habit to remember
Lucid Triple is offline   Reply With Quote
Old 10-05-2009, 09:01 AM   #5 (permalink)
jsobell's Avatar
This is normal and happens on almost all bikes. A sequential manual gearbox requires the gears be perfectly aligned for the selectors to change properly, so letting the clutch out slightly allows it to find its sweet spot and select as the selector forks slide on the shafts. The selectors themselves have teeth on the inside and slide over a toothed cog, so if the teeth are not perfectly aligned on each then it wont select the gear, and this is what you are experiencing. In reality it is relatively unlikely that the teeth will match up perfectly if the clutch has fully disengaged the gearbox from the engine, so either the back wheel needs to be moving or the gearbox side of the clutch does. If your other bike always allows the gear selection then it may be that the clutch has a tiny amount of drag, or even that it has enough viscousity in the oil to cause the gears to turn slightly.
Either way, nothing to worry about, just live with it
Cheers,
Jason
jsobell is offline   Reply With Quote
Old 10-05-2009, 05:48 PM   #6 (permalink)
Favourite Bike: All...
AaronP220R's Avatar
Other Motorcycle: 2009 Street Triple
Extra Motorcycle: 2004 GSX-R750 (track)
Not really. I use the engine to slow me down. It's RARE that I will do a 4th to 1st jump. That's how you wreck your stuff. If you're going 40 in 4th and run it down to first and let the clutch our, you're more brave than I.
Instead, agressive braking with hands and feets are along side blip-down shifting to keep the rear tire tracking straight.
AaronP220R is offline   Reply With Quote
Old 10-05-2009, 11:29 PM   #7 (permalink)
Down Shifting:
Thanks for all the good replies.
I wasn't trying to shift from 4th to 1st. I couldn't get past 3rd. Once I came to a stop, I couldn't get 2nd or 1st. Pull the clutch lever lightly got me to 1st, but I could hear clicking sound.
Old 10-06-2009, 01:05 PM   #8 (permalink)
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
Hold pressure on the shifter and rock the bike back and forth.
MacBandit is offline   Reply With Quote
Old 10-06-2009, 02:10 PM   #9 (permalink)
Down shifting:
I'll try that.
Thanks.
Old 10-06-2009, 05:16 PM   #10 (permalink)
Favourite Bike: Whichever one I'm riding
2wheel_Ted's Avatar
Same thing on my previous Honda. The rocking back & forth suggestion is a good one.
"We're so far behind, we think we're first."
2wheel_Ted is offline   Reply With Quote
Anyone go from Street Triple to Speed Triple? Or vice versa? sl10002001 Speed Triple Forum 18 11-28-2011 09:56 AM
Street triple screen on Speed triple Buster Speed Triple Forum 49 10-22-2009 02:34 AM
The All-Inclusive Street Triple vs Speed Triple Thread HandleOnTheRight Street Triple Forum 83 09-19-2009 10:34 PM
Speed Triple/Street Triple R Flickability MNDZA Speed Triple Forum 2 07-20-2009 01:23 PM
Triumph Launches the Street Triple as in STREET Triple! Aussiebikerdave The Rocket Science Forum 1 05-25-2007 09:20 PM
