I would start there. If you do find a leak then replace the part and completely flush out the old fluid and replace with new. Brake fluid is hygroscopic which means it absorbs water (even from the air) so if there is a crack or leak you need to completely remove the old fluid and replace it.
Moisture contaminated fluid is BAD. Lowers boiling points, corrosive to the system XYZ. So...actually, I would be safe and probably flush it anways. Especially if you're loosing braking performance after a spill. My first inclination would be to check the brake line fittings on the mastercylinder and caliper to make sure they're tight. They simply could have been jared in the lay-down and loosened a little. If you find a loose fitting, tighten it and flush the system. If you find a crack, replace and flush the system.
