Gear Indicator - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-27-2009, 05:22 AM   #1 (permalink)
Favourite Bike: Tiger 1050
Other Motorcycle: Tiger 885 (Steamer)
Extra Motorcycle: Honda Varadero XL1000
Gear Indicator
Tiger rider sneeking in here for a quick question.
A friend has a Street 3 and told me he was begining to experience erratic read outs from his gear indicator. I had no idea one was fitted incorporated with the instrument console, wish the Tiger had
Now I assumed that it would function in the same way that all the aftermarket ones that I know of do i.e. the revs are mapped to a speed range read from either a digital speedo or from a pick up on one of the wheels.
After doing a couple tests he reported back that it actualy changes with the bike stationary and even with the clutch disengaged.
Now I am pretty sure it is not some 'counting' device on the change shaft otherwise it would get totally lost the first time you found a false neutral, so I am now thinking there must be some switch gear internal to the gearbox.
Can anyone verify how the position signal is achieved?
I also was curious if there was some way this could be achieved on the 1050 but seeing another post stating that the Speed 3 doesn't have it I am also guessing that it's a peculiarity of the 675 engine / box.
Cheers
Niall
Serial Crash Bar Bender
Sin_Tiger is offline   Reply With Quote
Old 07-27-2009, 07:36 AM   #2 (permalink)
Diego's Avatar
Your logic is impeccable. It is indeed a switch arrangement within the gearbox.
The 675 gearbox was designed to incorporate it, and so was the instrument cluster.
With the 1050s receiving new instruments in... what, the 2008 or 2009 model year?... I thought maybe the newest ones of those might also incorporate a gear indicator, but I guess not. It would be very hard to retrofit one, I suspect, because of what would have to be done inside the transmission.
John
Old 07-27-2009, 10:02 PM   #3 (permalink)
Thanks, without looking at parts fiches I think it's probably not practicably achievable as you have alluded to. Pity, I do like elegant solutions.
Time to get that Acumen that's been lurking on the garage shelf down and get around to fitting it and tell my Street3 friend it might not be a cheap fix for his bike.
Old 07-28-2009, 07:41 PM   #4 (permalink)
vega 0's Avatar
You should tell your friend to inform the dealer of this problem. I know of a few people who have had the same problem, which requires a replacement part.
vega 0 is offline   Reply With Quote
Old 07-28-2009, 11:11 PM   #5 (permalink)
Thanks for that, he should still be in warranty but I'll warn him.:
Gear Indicator for S3? HiFiSkipper Speed Triple Forum 1 07-05-2009 09:50 AM
Gear Indicator pete241150 Hinckley Classic Triples 1 07-22-2008 06:04 AM
Gear Indicator rob-cyn Triumph SuperSports 9 06-01-2007 01:29 PM
Gear indicator Jacsje Speed Triple Forum 9 05-16-2007 04:43 PM
S4 Dg8 gear indicator neil1052 Triumph SuperSports 5 02-19-2006 10:37 PM
