Hello I had the exact same problem. After searching a bunch of forums they all said it was the sleeve at the back of the tank (the one under the seat). I found that very hard to believe so after tightening everything i could find and still no solution i pulled the bolt out at the back of the tank then removed the bolt sleeve and put some grease on it and the ends of it. problem solved. give that a try i hope it helps.
