First Service/break-in oil - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.comSportbikeTrackGearNew BonnevilleMotorcycle.com Classifieds!
Closed Thread
Old 07-09-2009, 10:55 AM   #1 (permalink)
Dealer Recommends First Service At 500 Miles, Im At 1000 And Money Is Really Tight. Is It Really Important To Get The First Service At 500 Miles? Is The Oil Break-in Oil Or Is It Just Regular Oil And Can I Go A Little Bit Longer.
tearuridolsdown is offline
Old 07-09-2009, 03:37 PM   #2 (permalink)
Favourite Bike: All...
AaronP220R's Avatar
Other Motorcycle: 2009 Street Triple
Extra Motorcycle: 2004 GSX-R750 (track)
YES!!! There's a special breakin only oil in the motor right now to help things wear in correctly. After that 500 miles it needs to get OUT and be running on synthetic.
You frist service will be under $200.
Stop driving it until you can get it done.
AaronP220R is offline
Old 07-09-2009, 04:42 PM   #3 (permalink)
Stampy's Avatar
You need to get that oil out! A lot of guy's change their dino oil & filter at 500km's and replace it with more dino oil for another few hundred K's just to ensure the ring's bed in properly, then change to full synthetic, but you need to get that old oil & filter out now due to normal contamanents that arise from a new engine bedding in.
Stampy is offline
Old 07-10-2009, 09:53 PM   #4 (permalink)
Favourite Bike: 09 Street Triple R
Ronin324's Avatar
Well the most critical thing in the first service is the oil change. Changing the oil and the filter is a pretty easy process and in my opinion there is not really a good reason to bring it into a dealer for that. just do it yourself. The other things that the dealer will check are pretty much the same things that are covered in the maintenance section of the manual. You will find out how much different the break in oil is from a synthetic oil when you put it in and fire it up. Its like a new bike.
Ronin324 is offline
Old 07-11-2009, 12:36 PM   #5 (permalink)
In my opinion, the most critical thing at first service, if done by the book, is to give the bike a complete going over, i.e. all the important fasteners, chain slack, ECU readout for errors, brake and clutch adjustments. These types of things CAN result in a life-threatening results, how would you like an axle nut to spin off while going 70 mph, lol?
I realize there might be some dealers who don't do it by the book, but the good ones will. My dealer had me come in at 800 miles, btw, before the first oil change.
Neanderthal is offline
Old 07-11-2009, 03:14 PM   #6 (permalink)
Favourite Bike: Street Triple R
Pay?
Not sure about the US but in the UK first service is labour free - or should be. All you pay for is the oil and filter so same cost as DIY!
Andy
Andybra is offline
Old 07-11-2009, 03:43 PM   #7 (permalink)
Diego's Avatar
Not that way in the US, alas. Only a few upscale brands of vehicles do that here.
John
Diego is offline
Old 07-12-2009, 04:08 PM   #8 (permalink)
Thanks for that AndyBra, I was allways under the assumption that the first service was labour free also, that was until my dealer wants me to cough up £110 for the first service, now I dont know if I'm being ripped off or if they can charge so I'm phoning Triumph to find out for def tomorrow.
Shado is offline
Old 08-21-2009, 08:13 PM   #9 (permalink)
I have just bought a Speed Triple from A1 Moto in York - asked the question re 1st service - said it would be about £70.00 (my Bandit only cost £37 via the local Suzuki dealership) - so I think they are putting a labour charge in there as well.
mikejhughes is offline
Old 08-21-2009, 11:48 PM   #10 (permalink)
Lightbulb
It's important to drop that oil. An oil change (DIY) can cost you as little as $25 if money is tight: Shell Rotella Synthetic T is like $20 (whole gallon) and Supertech ST7317 filter is $2 at walmart. Not what I would recommend or use for my bike, but if you must until you take your bike to your local dealer .. hey it's better than no oil change.
sirbe is offline
Closed Thread
1000 mile break in service... kidkazi Twins Technical Talk 1 10-06-2007 03:15 AM
Is there a break in map? 2Scared2Wheelie Speed Triple Forum 5 03-10-2007 10:48 AM
back from break in service natec Twins Talk 4 06-29-2006 05:10 PM
cost of 500 mile service and service plan xxxdog56 Sprint Forum 11 02-23-2005 02:18 AM
Triumph break-in vs. Motoman's break-in? Triumph SuperSports 3 07-14-2004 07:58 PM
