Front Brakes - Shimmy - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-04-2009, 01:33 AM   #1 (permalink)
Has anyone else experienced an ugly front end shimmy when braking hard? Under normal use, all is well, but a couple times now when braking hard, I get an ugly vibration/shimmy on the front end. I guess a trip to the dealer for a check is in order... warped rotor maybe?
srfjm is offline   Reply With Quote
Old 07-04-2009, 06:51 AM   #2 (permalink)
Favourite Bike: Street Triple
I am experiencing the shimmy on front wheel while braking hard also.
It usually occurs with the second and third hard breaking during a ride.
If you know the reason let us know.
szowinista is offline   Reply With Quote
Old 07-05-2009, 03:12 AM   #3 (permalink)
Favourite Bike: Street Triple R
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
Have you checked your front tire air pressures.
MacBandit is online now   Reply With Quote
Old 07-05-2009, 09:33 AM   #4 (permalink)
good point.
Actually I have my pressure below standard. 2,30 instead of 2,50
I will up the preassure, and see if it helps.
Old 07-05-2009, 01:16 PM   #5 (permalink)
MacBandit's Avatar
Standard pressure is 2.35bar so your fine at 2.3.
Old 07-05-2009, 01:21 PM   #6 (permalink)
MacBandit's Avatar
Something to consider is that maybe your front suspension is too soft. Remember the more you compress the front suspension without compressing the rear the steeper the steering angle becomes and the shorter the trail. This causes the steering to become quicker and less stable. If you have an R or have replaced the suspension I can give you some tips on adjustments that will help prevent this.
Old 07-05-2009, 01:59 PM   #7 (permalink)
Yeah I'm running my tire pressure on spec. The front suspension may be an issue, but I don't think it's causing this... though I could be wrong. I really hope it's something wrong with the brakes that can be fixed (under warranty hopefully). I wouldn't want to have to replace my forks in order to have safe braking
Old 07-05-2009, 02:11 PM   #8 (permalink)
MacBandit's Avatar
If it's only occasionally then it could be a combination of hard braking and the specific road conditions you are going over. Another question would be how much tire do you have left?
Old 07-05-2009, 08:12 PM   #9 (permalink)
Only 1500 miles on the bike... plenty of tire left.
What I did notice today though, is that the outer rotors have play in them where they're attached to the inner gold mounts. Is that normal?? I never noticed that on any other bike I've owned, and when I check my buddy's 848, his were solid - no play.
Old 07-05-2009, 09:37 PM   #10 (permalink)
MacBandit's Avatar
Yes the rotors are suppose to have play. They're called floating rotors. It allows the rotors to be a little out of true during heat up and cool down and over the life of the rotor and still allow you to have maximum braking without pulsation.
Front end shimmy caused by OEM tyres? SRMC_Scorpio Twins Technical Talk 4 05-03-2009 01:29 PM
Front wheel shimmy cm08 Sprint Forum 11 01-16-2007 08:14 AM
Shaking front end when applying front brakes. stealthy1 Daytona Deliberations 10 11-23-2006 05:34 PM
Shimmy in Front wheel - Tried everything aleka Twins Technical Talk 10 10-03-2006 07:36 PM
Front Brakes Bort The Rocket Science Forum 1 01-19-2006 12:36 PM
