Triple R fork seal blown - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.comHonda PowersportsSportbikeTrackGear
Old 06-03-2009, 01:15 AM   #1 (permalink)
Newbie
Question Triple R fork seal blown
I have about 150 miles on my 09 Triple R and just had it serviced for a blown & leaking front fork seal. Has anyone had a simliar problem or have any thoughts on the topic?
TripleRBoricua is offline   Reply With Quote
Old 06-03-2009, 01:22 AM   #2 (permalink)
Just curious, have you done any of these:
1. Wheelies?
2. Compressed forks way down with tie-down straps at any time?
3. Hit a bad pot-hole or speed bump?
4. Run through a lot of sand or mud?
Not trying to accuse you of anything, those were just the first things that come to mind when talking about fork seals. Hope everything works out well for you!
Neanderthal
Neanderthal is offline   Reply With Quote
Old 06-03-2009, 01:26 AM   #3 (permalink)
Newbie
The only possibility would be #2, as I transported it after purchase. Thanks for your thoughts & quick response.
TripleRBoricua
Old 06-03-2009, 11:08 AM   #4 (permalink)
Compressing the forks during transport normally does not cause an issue unless you compressed them all the way and for a long time. Even then, I've seen bikes go cross-country without issues, so that may not be the cause of your problem, but it's a starting point. There may be a totally different reason, including plain-old mis-assembly at the plant, which in your case might be the more likely scenario.
Neanderthal
Old 06-04-2009, 01:17 AM   #5 (permalink)
Favourite Bike: Street Triple R
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
With so few miles on it my guess is definitely a cut during installation. If it reoccurs then you may have a scratch in the fork leg but they should have checked that when they were replacing the seal.
Oh, and no my R with 1400miles has not had any leaks.
MacBandit is online now   Reply With Quote
Can a TT600/S4 fork seal be changed without disassembling the fork? BombFactory Maintenance & Workshop Talk 3 01-22-2007 02:44 AM
blown seal. OT Limey Speed Triple Forum 1 12-30-2006 01:51 PM
Blown Oil Filter Seal, Narrowly Escaped Diasater kliff Twins Talk 2 08-11-2006 09:52 AM
Blown Oil Filter Seal, Narrowly Escaped Diasaster TheLiveEye Twins Talk 0 08-11-2006 09:32 AM
fork seal blown?? brittour95 Maintenance & Workshop Talk 32 12-30-2003 09:09 PM
