Ive been looking at maybe purchasing a salvage street triple. i found one and it wont start because its missing the gauge cluster. and it also has a open spot udner the seat that looks like something use to be there and plugged in. there is jsut a wire wit ha plug now... is that where the ecu is located? and if that is indead missing is ther any other potion other than oem?
The empty plug under the seat is normal, I believe the dealer uses it to hook it up to a diagnosis computer. The ECU is located under the gas tank, on top of the air box.
