check engine light - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 02-25-2009, 02:23 AM   #1 (permalink)
Favourite Bike: Mine. Street Triple R
Other Motorcycle: R6S
check engine light
so i was wondering my check engine light came on but the bike is running great, i took off my rear turn signals and now dont have any on the back of my bike just the wires tucked away now and only the rear brake light, i was wondering if this is why my check engine light was on?
Be the change you want to see in the world.
street_triple_R is offline   Reply With Quote
Old 02-25-2009, 04:40 AM   #2 (permalink)
Diego's Avatar
No, I don't see any reason why the signals alone should have anything to do with that warning light.
If there wasn't some sort of electrical mishap during the installation (one that is, hopefully, now cleared) to account for the fault light, then the only way to find out the reason for it will be to connect a code reader to the connector under the seat and retrieve the fault codes.
The indication may clear on its own after three full warmup and shutdown cycles, provided there is no further problem, but unless you actually read the codes you may never know for sure why it occurred.
John
Old 02-25-2009, 10:40 AM   #3 (permalink)
Favourite Bike: 2008 Street Triple
Other Motorcycle: 2003 Honda ST1300
Street,
Did you reconnect the Engine Management System wire? From my experience, I disconnected the Engine Management System connector during the disassemble of the OEM undertail. When I started the bike after installing Carbonuk undertail, the Check Engine light came on the instrument panel. I reconnected the Engine Management connection. It still came on the instrument panel. I called the dealership and they said it was probably a code that had to be cleared. After so many starts (not sure how many), the check engine light didn't light up any more.
goose2241 is offline   Reply With Quote
Check Engine Light Leland Daytona675 Forum 13 04-19-2009 04:31 PM
check engine light aisurffish Tiger Workshop (archive) 7 03-12-2008 09:57 PM
check engine light came on Euro Speed Triple Forum 13 01-13-2007 03:39 PM
check engine light robbo1847 Maintenance & Workshop Talk 4 07-17-2006 04:35 PM
Check engine light Speed Triple Forum 1 07-02-2004 02:19 PM
