Is the lack of play on the T-cabel the reason that the revs are so variable as you go over horrible street obstacles
No, actually, the general experience has been that Street Triples with excess throttle play are worse about that. It definitely is a sensitive throttle in any case.
There is a trick to working around that business with bumps, though, variously described as keeping your wrists or elbows loose, or mentally uncoupling your hands and forearms from the rest of your torso, so that you don't transmit unwanted throttle input during those road-induced transient motions.
