Wrong tire mounted....noticed 1200miles later - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-17-2009, 11:53 AM   #1 (permalink)
I was installing my daytona shock on my Street Triple yesterday and noticed 160/60/17 on the sidewall of the rear tire.
I got a flat 20 miles after I brought the bike home from Central California. I took it to an East Bay Area shop to change the tire. I've put about 1200 miles on it since October and just noticed the sizing.
It should be a 180/55/17 tire, not a 160/60/17
What are the benefits of the 180 rear? This is my 2nd bike and total miles of riding are under 5500 miles. I am thinking about a trackday in a month or two when the weather gets better.
I was going to go the Triumph shop later and see what they will do. Im sure they have it in the computer because I also bought the visor kit that day.
PsychBiker is offline   Reply With Quote
Old 02-17-2009, 01:19 PM   #2 (permalink)
You should have them change it. I'm surprised that it doesn't look that unusual, but I guess a 160 over a 5.5 inch rim wouldn't look pointy since it has to reach out to the edges of the rim. Either way in this case it's just the wrong tire size for a 5.5in rim.
Sometimes people put a 180/55 or 190/55 in place of a 190/50 to quicken the steering a bit. The second # is the sidewall height, and is a percentage of the tread width (first #), so a 190/55 would have a taller profile than a 190/50. A 160 will have a very flat profile stretched over a 5.5in rim, and you won't want that on the track, or street for that matter.
Zane
2003 Triumph Speed Four
2006 Honda RC51
2009 Triumph Street Triple R
zaner30 is offline   Reply With Quote
Old 02-17-2009, 10:07 PM   #3 (permalink)
Favourite Bike: 2010 Rocket III Roadster
I would demand that the shop who put the tire on, replace it with the correct size for FREE! That is rediculus, if they are a motorcycle shop they should know to replace the tire with the correct size.
BRich is offline   Reply With Quote
Old 02-17-2009, 11:13 PM   #4 (permalink)
Favourite Bike: '08 Street Triple
+1. Their error and they should be embarrassed about it. They should replace it FREE OF CHARGE!
Ken M1 is offline   Reply With Quote
Old 02-18-2009, 01:30 AM   #5 (permalink)
Favourite Bike: Street Triple R
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
I have to say that from the image I would be more inclined to say that the tire size is misprinted. If that were in fact a 160 than the rim would be wider than the edges of the tire and that is clearly not the case.
MacBandit is offline   Reply With Quote
Old 02-19-2009, 01:08 PM   #6 (permalink)
Triumph specs say 160 on a 5" rear and 180 on a 5.5" rear
The tire turns out is also 3 years old.
I'm a semi new rider but want to trackday soon.
Should I change it or stay with it? Will handling be easier or not with a 180?
What about safety? Should I be worried about the bead popping?
Old 02-19-2009, 03:08 PM   #7 (permalink)
Not necessarily, a 160 is meant for a 5in rim, with air in it it would reach the edges of a 5.5 rim, the sidewall would be flexible enough to do that. It's hard to tell from the pic, but comparing it to how a 180 looks on a 5.5, the sidewall doesn't bow out as much as they are supposed to. REPLACE the tire with a 180.
There are zero positives for keeping the wrong tire size on, only potentially serious negatives. In this case, especially as a newer rider, it's not an issue of "easier" handling or preference, the thing was designed to run with a 180/55. It might not be too noticeable at moderate street speeds, but think about this... would you want to be at full lean and have that bead moving around on the rim?
I can't, in good conscience give you any other advice. I know tires can be expensive, but if the shop won't do the right thing and replace it, do it yourself.
2006 Honda RC51
wrong thing at wrong time fugitive Biker Hang-Out 9 09-16-2008 09:03 PM
New Front Tire Mounted 1050STrider Sprint Forum 2 03-22-2008 01:43 AM
Wrong primary-case = wrong timing happyray Classic, Vintage & Veteran 3 04-05-2007 11:27 AM
Low mounted can or high mounted? Trend? Fenster Speed Triple Forum 28 02-25-2007 09:11 PM
Tire mounted backwards vol245 Twins Talk 7 04-24-2006 05:15 AM
