Adjusting the throttle cable. - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Ontario TourismMotorcycle.com
Old 01-27-2009, 01:18 PM   #1 (permalink)
Favourite Bike: All...
AaronP220R's Avatar
Other Motorcycle: 2009 Street Triple
Extra Motorcycle: 2004 GSX-R750 (track)
My Street Triple has a lot of movement in the throttle before you engage the fuel. My step-father and I gave it a whirl two weeks ago trying to use the owners manual which simply stated "remove fuel tank, remove air box, adjust cables". We removed the fuel tank with not too much effort but the air-box is where we hit the snag and got cold feet. I would really like to get all the slack out of my throttle. Is there a trick to the air-box removal or a better way to go about it? Or should I just let the dealer do it? We're both mechanically inclinded, but there's a lot of stuff on/around the air-box and I don't want to mess up an expensive bike.
Thanks,
Aaron
AaronP220R is offline   Reply With Quote
Old 01-27-2009, 03:39 PM   #2 (permalink)
Favourite Bike: '08 White Street Triple
D'Artagnan's Avatar
Other Motorcycle: '07 Black Ninja 250 -sold
Aaron, you may already know this, but minor throttle cable adjustment can be made by separating the little rubber protector just a few inches down the cable from the throttle (right in front of the right handlebar) and and then wrenching the adjustment nuts a bit.
Best,
d'Artagnan
Triumph f/ All and All f/ Triumph
D'Artagnan is offline   Reply With Quote
Old 01-27-2009, 04:12 PM   #3 (permalink)
AaronP220R's Avatar
No, I didn't know that. And I have no clue what you're talking about. I'm not sure if it will take out what is currently there, but it would be better than what it is.
I'll try to verbally depict the travel. If 90 degree's is strait up (and that's 100% full rest for the throttle handle) I’ve got to turn the handle about 25-30 degrees before I actually start to deliver throttle or about 1/2-3/4 of an inch. If I'm going to do a full throttle run I’ve actually got to clock my hand 25-30 degrees advanced from 90 to be able to open to full throttle without changing hand position. And there's no way I can go comfortably from no throttle to full throttle without extreme extension of my wrist which is another extreme bother of mine.
Thanks,
Aaron
Old 01-27-2009, 04:24 PM   #4 (permalink)
D'Artagnan's Avatar
Aaron, w/ that much play I would strongly suggest that you stop by you dealer's service department and let them take a quick look at it. I would do that BEFORE messing w/ the inline adjustments. Certainly sounds like a lot of play.
d'Artagnan
Old 01-27-2009, 04:55 PM   #5 (permalink)
AaronP220R's Avatar
Well, when I bought the bike it had that much play in it. Upon reading the owners manual, the recommended setting is 1/8 inch play with is considerably less than what I have. When I took the bike in for it's first 500 mile service I made a comment about the amount of play in the throttle. They said it was within spec so I simply left it at that figuring they would know more about it than I would.
Upon trying to tackle this task my self I could see why they would say it's in spec. It seems like a rather big pain in the butt to get in there and do the actual adjustment. Looking to save time and not have to deal with it, which I will bet moeny this is the case; they simply said it's in spec.
So, i'll make a call to the dealership and set up a time to have it adjusted to something more of my likings. I was hoping it would be something easily done and not have to jump through the hoops of messing with the dealer but all well. I simply can't live with that amount of play anymore.
Is there anyway to shorten the closed-to-full throttle distance?
Old 01-27-2009, 05:50 PM   #6 (permalink)
Favourite Bike: ST675
Other Motorcycle: SV650
Extra Motorcycle: GasGas Pro 300
[defective link removed; sorry, no updated or redirected link found - Diego]
pretzel is offline   Reply With Quote
Old 01-27-2009, 06:33 PM   #7 (permalink)
AaronP220R's Avatar
You gave me gold! Thanks!
Old 06-23-2009, 10:55 PM   #8 (permalink)
AaronP220R's Avatar
I've done it...just a few days ago.
Look for a rubber boot abot 2-3 inches before the grip.
The tank way is a PIA and is rather hard to do.
Old 06-25-2009, 02:01 AM   #9 (permalink)
AaronP220R's Avatar
I've found for some reason about ever 1,000 miles or so it needs re-adjusting.
Old 07-21-2009, 01:13 PM   #10 (permalink)
Favourite Bike: Street Triple
PorscheFanatic's Avatar
Other Motorcycle: 996 Carrera C4S
How to adjust throttle slack
I noticed that my throttle has little too much play, has anybody adjusted their throttle? or is this something I need to go to the dealer for?
PorscheFanatic is offline   Reply With Quote
Adjusting the Closed Throttle Position. thinkjerm Triumph SuperSports 0 07-20-2008 04:33 PM
Adjusting throttle cables? Am i missing something? Railer Sprint Forum 12 07-12-2007 09:20 AM
adjusting throttle play - how the hell to reach the adjusters jpeake Speed Triple Forum 10 05-09-2007 09:21 PM
throttle cable trumpetfan Twins Technical Talk 3 03-31-2007 11:10 PM
Throttle cable ??? 99 vs 02, 1x or 2x cable? robadele Sprint Forum 8 01-07-2005 08:25 PM
