Home made Rad Guard - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-19-2008, 01:22 AM   #1 (permalink)
Favourite Bike: '08 Street Triple
Home made Rad Guard
Sorry it took me so long to post. For anyone wanting a cheap rad guard, just get some hole punched sheet aluminum. Measure across radiator (between tanks...you're only trying to protect the fragile fins). Cut sheet a bit oversized. Now squeeze between tanks and trim as necessary to fit snug against the rad. Cut (top to bottom) with about 1/2" over. Now replace onto rad and set it with 1/4 excess top and bottom. Use that to run zip ties through around rad bracket. DONE. I used Helix Mesh round hole aluminum mesh (about $35). All you need is the aluminum mesh, tin snips, 4 long thin zip ties, and 20 minutes.
Ken M1 is offline   Reply With Quote
Old 12-19-2008, 11:22 PM   #2 (permalink)
Great close-up photo there! This is something I will be doing as a winter project. I think I will paint my screen black though.
Neanderthal
Neanderthal is online now   Reply With Quote
Old 12-20-2008, 12:24 PM   #3 (permalink)
Favourite Bike: Street Triple R
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
That's exactly what I've been trying to do but no where around where I live sells punched aluminum. The only place that did isn't selling any metal right now due to the drastic decline in scrap metal prices. I did find some online but it would have cost about $60 for the piece.
MacBandit is offline   Reply With Quote
Old 12-20-2008, 03:12 PM   #4 (permalink)
Hi MacBandit. I got my mesh at www.newenough.com click on "Parts" and type "Helix mesh" in the search. They have different hole styles. I used the "Round hole" style. Hope that helps ya.
Old 12-20-2008, 08:13 PM   #5 (permalink)
MacBandit's Avatar
Thanks Ken. It's still 51.30 shipped so I'm going to hold off for now. I got a Fenda Extenda which will help keep stuff from the tire hitting the radiator.
Old 07-22-2009, 02:36 PM   #6 (permalink)
Favourite Bike: Triple R
Scraaaaaape
Yes that's the sound of an ages old post being brought to the surface. But I think it's better to continue than create multiple threads.
I'm wondering for those who have done this, have you seen any heating/cooling issues long term, particularly in summer stop-n-go traffic?
Looking at the above grate, it looks like a 60 degree pattern (for any hole, there are six evenly surrounding it). I'm guessing the pattern in the picture is 1/8" holes on 3/16" centers, which has an open area of only about 40%.
If I look at similar protectors for cars, they're around 60+ % open area. 1/4" on 5/16" centers, or 5/16" on 3/8" centers would get to that figure, but the holes are starting to get pretty big, if you could even find that combo.
I'm not a mechanic, and I'm certain the radiator has sufficient cooling while moving, but would moving the plate 1/4" out from the radiator surface allow the fan to be more efficient? I think someone mentioned they did that in another thread. The main concern being warranty issues and overheating.
Wire mesh can easily get upward of 70-80% open area, but would need some kind of frame. Both are available from Amazon.com for under $20 for 12x24" sheets. (search for perforated aluminum or wire mesh). Cheap frames could be made from the "U" stock stained glass folks use.
A grill full of fireflies might make a cool third headlight, but it's a pain to clean.
So, long term reports? Anyone have to give up the home brew design? Of course, summer around here has been so cold, probably don't even need the radiator
pelipen is offline   Reply With Quote
Old 07-22-2009, 04:49 PM   #7 (permalink)
MacBandit's Avatar
You can also get honeycomb perforated aluminum sheeting which would allow a lot more air flow then round holes.
http://www.google.com/products?q=hon...l=en&scoring=p
Also WPS sell this stuff as well so any motorcycle shop should be able to order it for you.
http://www.wps-inc.com/wps/WICATALOG...GO=Page%23
Old 07-22-2009, 09:55 PM   #8 (permalink)
lmnop88's Avatar
Nice work! That's something I was looking to do when I had the bike, but was hesitant b/c I was worried how the end result would look. Judging by your pic, it looks pretty good!
lmnop88 is offline   Reply With Quote
Old 07-23-2009, 08:53 PM   #9 (permalink)
f1xedgear's Avatar
My home-made guard, no probs. Have made it through 1 1/2 North Carolina summers w/o a blip. Hope this helps.
See at http://www.triumphrat.net/street-tri...-homemade.html (bottom p. 1)
f1xedgear is offline   Reply With Quote
My Scrambler with Norman Hyde Seat and Wire Exhaust Guard & "Home Made" Luggage Rack GleaminTwin Twins Technical Talk 8 02-10-2009 01:42 PM
Home made Bling daleCarlsbad Twins Technical Talk 11 12-23-2008 09:25 AM
Lilly has made it home. BADBUD Classic, Vintage & Veteran 22 12-14-2007 05:41 PM
home made scrambler ----- tr6c Twins Talk 17 07-20-2007 01:55 PM
air box removal - home made whoa Club Cafe' 11 03-21-2006 12:11 AM
