How much fork oil? - Triumph Forum: Triumph Rat Motorcycle Forums
Steamer - Mods & Workshop Workshop and technical talk for the 900 carb Tiger.
post #1 of 9 (permalink) Old 01-24-2015, 09:06 PM Thread Starter
Main Motorcycle: 1998 Tiger
Other Motorcycle: 1973 Z1 900
Extra Motorcycle: 1977 KZ 1000
How much fork oil?
So Id like to change the fork oil in my 98 Tiger. I have the Triumph Service Manual, not very helpful compared to my old KZ manuals.
My bike the VIN is 62800ish so the fork should be Showa and the oil should be filled to 144mm from the top.
My question is, and I hope someone here can help, what does that translate to in terms of volume? I'd like to just pour in the oil and check that it is correct, rather than trial and error to get the correct measurement from the top of the fork.
ID:	230249   Click image for larger version
BC98Tiger is offline
post #2 of 9 (permalink) Old 01-24-2015, 09:10 PM
Main Motorcycle: 08 Sprint ST ABS
Dralb's Avatar
You are better off using a level over a capacity. Sometimes they list both, sometimes they don't. If you don't have a gauge, you can cut a zip tie or something to the proper length and fill up to that level.
Dralb is offline
post #3 of 9 (permalink) Old 01-24-2015, 09:14 PM Thread Starter
Yes, I'd certainly check that the "level" is correct, but I was hoping to get an idea of volume so I could at least get it close prior to checking the level.
Cheers,
Ross
post #4 of 9 (permalink) Old 01-27-2015, 04:32 PM
Main Motorcycle: Triumph Tiger 800XC
NORTY FLATZ's Avatar
Other Motorcycle: 2016 Harley FXDL
What viscosity oil are you using?
Shell makes a dandy fork oil called TELLUS.
It comes in many viscosities. I use a combo of #32 and #46.
MSF RiderCoach. Retired!
NORTY FLATZ is offline
post #5 of 9 (permalink) Old 01-28-2015, 02:39 PM Thread Starter
I hadn't quie decided on fork oil weight. The service manual says 10W20 for the Showa forks.
But hrere's the deal. I decided to attack what I feel is the root of the squishy forks, so I ordered new springs form Racetech.
I have a litre of 10W fork oil on the shelf in the garage. So when the springs arrive I'll use that and see how it goes.
Cheers,
Ross
post #6 of 9 (permalink) Old 02-24-2015, 12:15 AM Thread Starter
I ordered new springs from Race Tech. I dismantled the forks to install them, but they were the wrong ones. New ones are on the way.
But as to oil quantities. I dumped out the old oil into a measuring cup. It measured about 600ml. That seemed like a lot of oil to me.
So with springs out, fork tubes compressed, I put in 600ml of oil. Measured down from the top of the fork tube. It was pretty close to the spec of 144mm.
Cheers,
Ross
post #7 of 9 (permalink) Old 12-07-2015, 11:54 PM
I use a 50/50 blend of 10w & 15w fork oil. 650 cc per side works well for aggressive riding on gravel roads. Been doing nigh on 15 years with these specs.
Ken / Fishnbiker,
on Vancouver Island, BC
& Felix, 95 black Tiger
& Buzz, 08 Blue Suzuki DR650
Fishnbiker is offline
post #8 of 9 (permalink) Old 02-04-2017, 05:07 AM
more oil means less air... less dive, and a more firm ride. more oil will firm things up but can eventually make for a harsh ride.
beezerboy is offline
post #9 of 9 (permalink) Old 02-04-2017, 08:53 AM
Main Motorcycle: Bonneville black 2007
sonicboom's Avatar
Other Motorcycle: Honda CBR600RR
Extra Motorcycle: Honda CB500F
I picked up a little fluid pump over at Harbor Freight. I just add back in what I pump out.
sonicboom is online now
Fork oil level recommendations.Progressive Fork Spring installation SST Cruisers - America, Speedmaster 2 05-17-2012 01:00 PM
Fork Oil and Oil Level for Race Tech Spring StreetTripleDan Air Cooled Twins Technical Talk 3 03-07-2012 05:00 PM
73 Tiger question on Fork Oil and engine Oil leak oscarat Classic, Vintage & Veteran 2 11-15-2009 09:25 PM
Fork Oil - Increasing viscosity and oil level? NikosR Sprint Forum 9 04-21-2007 04:12 PM
speaking of oil...steamer fork oil amounts? flyintiger Tiger Workshop (archive) 2 02-22-2005 11:45 AM
