'96 Tiger Main Jets and Fuel Consumption - Triumph Forum: Triumph Rat Motorcycle Forums
Steamer - Mods & Workshop Workshop and technical talk for the 900 carb Tiger.
Old 11-04-2012, 07:39 AM   #1 (permalink)
Main Motorcycle: 1996 Triumph Tiger 900
simonweller's Avatar
What are the standard jets for a 1996 Tiger - Mikunni carbs?
Mine has had the right hand air box opened up, dynojets, K&N air filter and Renegade silencers.
It goes well on the standard gearing but the fuel consumption is far too high. (37 mpg motorway cruising, 35 mpg A roads, 29 mpg being caned)
I'm in the process of repacking the noisy exhausts to quieten them down but I may have to close off the right hand air intake again and return the jetting back to standard - although I'll probably have to have them slightly richer to allow for exhausts and K&N.
It currently has 130 main jets with the centre needle one notch higher.
Simon
Brighton, England
1996 Triumph Tiger 900, 1979 Moto Guzzi T3, 1973 MZ ES 250/2
simonweller is offline   Reply With Quote
Old 11-05-2012, 09:22 AM   #2 (permalink)
Main Motorcycle: Own a 95 Super111.96 Tige
threepot's Avatar
Other Motorcycle: 96 black Tiger. 73 CB125
Extra Motorcycle: None
try http://www.worldoftriumph.com/sectio...FSbMtAodRG0A5Q
My 96 Tiger only about 35mpg Not as good as my Super3..have had over 60! Have cleaned carbs etc but may change o rings next,see if that improves? Why are they called 'steamers'? I have noticed a little steam from left exhaust on occassion,dont seem to be losing water,or noticed oil contamination? Hope its not signs of haed gskt failure
threepot is offline   Reply With Quote
Old 11-13-2012, 10:23 PM   #3 (permalink)
Main Motorcycle: 98 steam driven Tiger
Other Motorcycle: CRFX 450 honda
Extra Motorcycle: 95 steam driven tiger
105 mains and #40 pilots
clip needle in middle position on all three
snorkel capped and stock exhaust
mustang is offline   Reply With Quote
Old 11-20-2012, 11:54 PM   #4 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
Just as a reference, my '98 Steamer with Keihin carbs has never done better than 43mpg (US), and more typically runs around 38mpg (again, US). Looks like you're in the UK? Are you using Imperial gallons here? If so, you're not that far off for fuel consumption.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is offline   Reply With Quote
Old 11-25-2012, 04:14 AM   #5 (permalink)
If only! You're right I am in the UK and 43 mpg US equates to 51 mpg UK.
I would regard 43 mpg UK as acceptable and 51 mpg UK as very good going. There are 4.54 litres to an imperial gallon and 3.78 to a US gallon.
I've been busy at work but should have the exhaust system back together in the next few days and wil be able to see if rebuilding that had any effect. Then it'll be a trip to a dyno to see what the fuel/air ratio is like.
Simon
Brighton, England
Old 01-15-2013, 04:52 AM   #6 (permalink)
Main Motorcycle: 1993 Tiger 885
Other Motorcycle: 1976 Yam XS650
Extra Motorcycle: 1975 Honda 400/4
They are called Steamers because they have a tendancy to boil over when stood in traffic on a hot day! The injection model next is called a Girly because the tiger stripes on the fairing look like big eyelashes ....
jacksdad is offline   Reply With Quote
Main Jets & Pilot Jets ggRAT Club Cafe' 44 05-16-2013 03:15 AM
High fuel consumption on my Tiger xuniter Steamer - Mods & Workshop 0 03-26-2012 05:00 AM
Bonnie pipes, jets and fuel consumption Drifter_Yank Twins Technical Talk 29 09-20-2011 06:42 PM
Pilot jets vs main jets - what do I install? WBAD Twins Technical Talk 11 08-17-2009 05:54 PM
main jets k_dencuz T3 Sport / Touring Forum 3 03-13-2008 09:33 AM
