I'm new to motorcycles and need some help. - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 12-02-2008, 01:55 PM   #1 (permalink)
My dad has a 2000 triumph RS and i was wondering if the 2000 sprint St body fairings would fit on a 2000 triumph RS.
My dad lets me use the bike because he also has a ducati 999.
If anyone can help I thank you very much.
-Jordi
2000sprintRS is offline   Reply With Quote
Old 12-02-2008, 02:26 PM   #2 (permalink)
Favourite Bike: '01/'06 Sprin/tona RS
kredge's Avatar
Other Motorcycle: '79 T140E
I haven't personally tried it but looking at my RS and pictures of ST's I'd say the ST side panels will not match the RS upper and belly pan. So if you want to turn your RS into an ST you'd need to have a complete fairing set with brackets. I've heard the steering head geometry is a little different too so I'm not sure if that would affect the fitment of the ST upper fairing.
You don't like the look of the RS?
kredge is offline   Reply With Quote
Old 12-02-2008, 02:38 PM   #3 (permalink)
No I like it, I just also like the look of the St alot as well.
Its hard to choose.
Also if anyone has relocated the exhaust under the seat or if they are smaller aftermarket exhausts.
thats what it looks like ill get better pics.
Old 12-02-2008, 03:26 PM   #4 (permalink)
oldndumb's Avatar
Welcome to the forum, 2000sprintRS.
I'm thinking the answer to your question is going to be yes, the ST panels can be made to fit an RS. However, I'm not sure you would want to do it after figuring out the cost. As in all things motorsports related, it becomes a matter of how much money you want to spend. You can look at bikebandit to see all of the various bits and pieces you would need to complete the transformation. They = $$$$!
iconhttp://www.bikebandit.com/triumph-motorcycle-parts-2000/oem-parts
Of course, it becomes a different matter if you have a donor bike, or a source for all of the pieces second hand.
Speaking for myself, I think the RS is one of Triumph's best looking bikes as it is.
Oldndumb
Caveat lector
Old 12-02-2008, 04:22 PM   #5 (permalink)
Favourite Bike: '03 Sprint RS
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Extra Motorcycle: CB400SF, 4 x DT175, MX80
I was thinking the same OnD. I reckon it would fit with little fuss as the frames are the same but the mounting framework is very different.
My thoughts centred around the bars and their narrowness compared to the ST which is quite a bit wider and a little higher. You may need to change them as well.
The mirrors are different as well.
As for the underseat exhaust there is a Wolf one and I think that I have seen a 2Bros but I would imagine that they would be relatively expensive to fabricate.
oh and welcome to the forum 2000sprintRS
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
Old 12-02-2008, 04:36 PM   #6 (permalink)
Anyone have the dimesions of a 06 exhaust for a sprint St.
I want to see if it would fit under the seat of the RS.
i have the one brake light in back which has signals included in it.
Old 12-02-2008, 06:48 PM   #7 (permalink)
You'd have to carve the underseat storage and (I think) the airbox as well as change the rear light position (as the 05 onwards are much higher in the back) to get a Trident or the like under there IMO.
I don't have the dimensions, sorry.
steventhechef
Old 12-02-2008, 08:16 PM   #8 (permalink)
Favourite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
I recently compared my 2000 RS to a friends 2001 ST, i can say without hesitation that the bodywork will not fit without a complete set of ST mounting tabs. The mirror mounting frames are also wider on the ST.
The RS and ST share none of the same tabs, the ST bodywork is MUCH wider than the RS fairings.
As for the exhaust, the RS has a double sided swingarm and the ST underseats will not fit without a custom made midpipe. Looks like a custom pipe will snake out a bit too obtrusively around the swingarm. The ST singe side swingarm makes room for the upswept pipe that the RS does not have.
If you are really possessed, you can retrofit an ST single sided swingarm, and then install the ST underseat exhaust.
so, seems that if you want an ST, it might be more cost effective to just buy one, since the Triumph resale values are so low....................
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
chefjpd is offline   Reply With Quote
Old 12-02-2008, 08:50 PM   #9 (permalink)
Favourite Bike: 06 Sprint ABS
Other Motorcycle: 02 Warrior 108CI
Extra Motorcycle: your sister
you will probably find you can buy a used 2000 ST cheaper than what it would take to convert the RS into a ST +/- a few hundred (and have 2 great triumphs) just a thought : :
wannab is offline   Reply With Quote
Old 12-02-2008, 09:34 PM   #10 (permalink)
Favourite Bike: 2006 Daytona 675
redmosquito1's Avatar
Other Motorcycle: Stolen 1999 Sprint ST
Hey 2000,
I am a firm believer in that if you want to make it work you can. You just need the funds time and tools to accomplish it. I can never remember who but there is a fellow on here that put Daytona fairings on his sprint, which goes to show it can be done.
However, as I'm quickly learning used parts are very hard to come by cheaply. Right now I have 250 invested in both the side fairings and 1 lower fairing. In the 3 months since my wreck I have only seen 3 upper left side fairings on ebay and I check it every day. That part alone is $100 plus. Then you must account for the mounting brackets and making new holes in the frame to attach them. Headlight brackets are different, and I beleive so are the mirrors.
Can it be done? yes, is the time/money needed to accomplish this worth it? in my opinion no, but for you maybe.
My advice would be to learn to love the RS look, or convince pops to sell it and buy an ST to your liking. Better thing to do though would be for you to save about $3500-5000 and buy a nice first generation (1999-2004) ST and ride the wheels off it. (dont crash it like me, it hurts and is expensive)
Tom
2006 Daytona 675
Keep the shiny side up, DUH!!!!
redmosquito1 is offline   Reply With Quote
if you REALLY know motorcycles Gone Cat Biker Hang-Out 14 02-05-2008 09:15 PM
U.S.A. motorcycles Lambo Sprint Forum 29 11-26-2007 12:05 AM
My 18 Motorcycles Jamo Biker Hang-Out 6 07-04-2007 05:41 AM
NCR Motorcycles Catenaccio Biker Hang-Out 7 06-25-2007 02:06 PM
NYC motorcycles markbvt Twins Talk 18 01-30-2006 01:24 PM
