Abrupt throttle action - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-23-2008, 09:16 PM   #1 (permalink)
Favourite Bike: 06' Sprint ST Red
BMWK100's Avatar
Greetings,
I just had my bike serviced at 24K and am scheduled to install my first replacement chain and sprocket on Friday. (I will be installing a new throttle cable and Pazzo levers too.)
Having said that, I have recently noticed that my throttle is very abrupt (sensitive?), especially at low speeds (below 40 mph). Is this something that most likely will be addressed with the new chain and sprocket? If not, are there any suggestions I can give my mechanic when I take it in? Any help will be appreciated.
P.S. I have never had this problem before.
BMWK100 is offline   Reply With Quote
Old 11-23-2008, 11:47 PM   #2 (permalink)
Favourite Bike: Black Thruxton 08
Other Motorcycle: Silver Sprint 06
This has been discussed many times before on this forum. Ensure that chain slack is kept towards the minimum specified but also ensure that you have at least some slack at the tightest point in the chain travel. A chain with even a whisker to much slack = a jerky response at slower speeds.
Cherrs, Simmo
Ride it while you can.
Simmo is offline   Reply With Quote
Old 11-24-2008, 12:12 AM   #3 (permalink)
BMWK100's Avatar
Thanks Simmo! I just got the bike out of the 24K mile service and had the chain adjusted.
Old 11-24-2008, 12:34 AM   #4 (permalink)
I would check the slack again. Dealers tend to leave a little more slack than less as this potentially places less stress on the driveline. You must have some slack otherwise you can face mechanical destruction etc etc but aim to minimise the slack.
Cheers, Simmo
Old 11-24-2008, 07:18 PM   #5 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
Actually, too much slack is better than too little as a general rule. Either way, the target is 1.5"/35-40mm at the tightest spot on the chain.
Cheers,
-Kit
Old 11-25-2008, 02:09 AM   #6 (permalink)
Favourite Bike: 2002 Sprint ST
Extra Motorcycle: 1979 Moto Morini 3 1/2 in
Before the chain I would think that a simple throttle cable adjustment would be in order.
Adjust the chain to the loosest end of the book stated specs in the proper manner.
I'll bet that between these two items you will cure your snatchy throttle.
If you or someone else adjusts your throttle make sure you check the front bars lock to lock with the engine running for over run before riding
Don
Originally Posted by BMWK100 View Post
Greetings,
Old 11-25-2008, 08:17 AM   #7 (permalink)
Favourite Bike: Sprint ST 1050
Throttle bodies out of sync could also cause this. Should have been done on the 24k service.
Pcdabbler is online now   Reply With Quote
Old 11-25-2008, 09:28 AM   #8 (permalink)
1050STrider's Avatar
Greetings,
Does the "I have recently noticed" happen to coincide with the time frame of "I just had my bike serviced"? If so I would be taking it back to the place of service and expressing my concerns about the throttle. Although, since you are replacing both the chain and the throttle cable on Friday I guess I would just live with it till then, after checking the chain slack of course so no damage is done from a too tight chain.
Just curious...why are you replacing the throttle cable? Installing new bars? Worn out already at 24k?
Speed Safe,
Don
06 Sprint ST
San Diego, CA.
1050STrider is offline   Reply With Quote
Old 11-25-2008, 09:38 PM   #9 (permalink)
BMWK100's Avatar
Speed Safe,
Don
Great point about the dealer as I'm not sure they did a throttle body adjustment. I'm changing the throttle cable just to be safe. No big expense.
Is there a way to have another dealer confirm if the throttle body adjustment was made during the 24K service?
Old 11-26-2008, 01:29 AM   #10 (permalink)
It should be in their checklist and notes. If it isn't I'd seek another dealer.
Abrupt Throttle Response swebb Twins Technical Talk 27 08-20-2009 04:20 PM
abrupt throttle response 2009 T100 hayekfan Twins Technical Talk 18 06-21-2009 10:51 PM
2008 Speed Triple abrupt throttle response chappong Speed Triple Forum 14 12-15-2008 11:15 AM
Abrupt throttle response on '05 under2x Sprint Forum 20 06-23-2008 04:25 PM
Quick Action Throttle? Spendthrift Speed Triple Forum 4 08-13-2007 03:49 AM
