Sprint 08 fairing removal - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports SportbikeTrackGearMotorcycle.com
Old 10-11-2008, 05:54 AM   #1 (permalink)
As I d'ont want to crack or break anything,How does the main fairing come off on my sprint after removing all visible screws ?
doctorfrank is offline   Reply With Quote
Old 10-11-2008, 06:53 AM   #2 (permalink)
Favourite Bike: 2006 Sprint, Caspian Blue
Other Motorcycle: 2006 FJR
Just make sure you have ALL the bolts out.
3 X lower fairing to headlight fairing.
2 X underneath the engine joining both sides
1 X at the rear of the side panel near the footpegs
3 X the radiator shrouds - once the shroud is off there is one behind into a bracket off the rad.
You will need to remove the black plastic covers either side of the tank (one has the small cubby box) 2 X bolts. Once removed there is one more bolt underneath that holds the side panel on.
Where your knee would be there is a peg that slids into a rubber grommet - just pull the fairing towards you from the side.
Just take your time and don't force anything.
And when you get the panel off make sure you have somewhere safe and soft to lay it down to avoid damaging it !!!!!
Fullchat is offline   Reply With Quote
Old 10-11-2008, 07:30 AM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Hello Drfrank
Hello and welcome aboard doctorfrank.
I hope you find our Sprint forum useful and enjoyable, we don't mind having a laugh here.
As you get time please read the forum sticky for new members.
I ask all noobs to do this.
cheers,
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 10-11-2008, 08:39 AM   #4 (permalink)
oldndumb's Avatar
Welcome to the mad house.
Fullchat gave a good description of the fasteners.
I would add one caution: Do not use the chrome swoosh as a handle at any time while manipulating the fairing. The mount points are fragile.
Oldndumb
Caveat lector
Old 10-11-2008, 06:04 PM   #5 (permalink)
I'd also add to remember where the chrome/ss bolts go and remember where the black ones go and put them back where they came from. The chrome/ss ones have a built in spacer that's there for a reason.
28016 is offline   Reply With Quote
Fairing Removal scubajosh77 Sprint Forum 16 06-22-2011 04:09 PM
Fairing removal? stu Sprint Forum 19 07-18-2007 05:57 PM
07 Sprint ST Fairing Removal Dlanod Sprint Forum 6 01-28-2007 01:26 PM
Fairing Removal? Fitch Sprint Forum 9 03-28-2006 06:44 PM
Right front fairing removal on 2005 Sprint St GeorgeT Sprint Forum 4 09-20-2005 04:50 PM
