Chain Advice - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Ontario TourismSportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsMotorcycle.com
Old 10-11-2008, 04:56 AM   #1 (permalink)
Favourite Bike: '02 Sprint ST
10-Ring's Avatar
Chain Advice
The chain on my 02 ST is in the process of falling apart in a hurry. Almost 29,000 miles out of the original. Not too bad I guess. Anyway, I need advice on a replacement. What brand, grade, type, ect.
I've spent the last 20 years without a bike and I've forgetten what little I knew about chains.
Pillage..... then Burn.
10-Ring is offline   Reply With Quote
Old 10-11-2008, 06:32 AM   #2 (permalink)
Favourite Bike: 2003 sprint current bike
triumphrat's Avatar
29,000 is a good run for a chain. For replacement you can use any brand chain O or X ring so long as it the right size. Don't forget to replace the sprockets with the chain as they will be worn too. I can assume you've been lubing your chain as you have 29,000 miles on it. The manual will have the the chain size listed
triumphrat is offline   Reply With Quote
Old 10-11-2008, 08:07 AM   #3 (permalink)
Favourite Bike: 2003 Sprint ST
Extra Motorcycle: 1400 intruder
I would buy a set with the chain and sprockets here is the best deal I have found so far http://www.sprocketcenter.com/p/3102...--triumph.html
flyinloww is offline   Reply With Quote
Old 10-11-2008, 12:45 PM   #4 (permalink)
10-Ring's Avatar
Thanks for the link.What about brands though? Anyone have a preference?
Old 10-11-2008, 04:51 PM   #5 (permalink)
Favourite Bike: 04 Sprint ST
Other Motorcycle: 05 DRZ 400
Extra Motorcycle: 09 TMAX
thanks for the link
just purchased a 17/45 kit form sprocketcenter.com should be powering the front wheel up in third now, thanks.
judas is offline   Reply With Quote
Old 10-11-2008, 05:07 PM   #6 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
I am very, very happy with my EK chain. High-quality o- or x- ring just like every other name-brand chain out there, except for the bolt-on master link. Made a huge difference for me: not only did I not have to buy a $100+ tool to install it, but it also automatically torques the sideplates to the correct depth.
18-tooth front sprocket with stock rear will make the bike much better than stock around town without making much difference in highway miles.
Cheers, HTH,
-Kit
Old 10-12-2008, 01:50 AM   #7 (permalink)
Favourite Bike: 10 Street Triple
Other Motorcycle: 99 Trophy 1200
I just did my chain and sprockets too. I went with a JT sprocket set in the stock 18/43 because I'm happy with the performance they give. The chain is teh same one that came from the factory, a DID x-ring. You're looking for a 530/108 chain if you want a direct replacement.
I used the sprocket center too, they're a good bunch of folks. I used them again for the Thunderbird I'm restoring.
I did the sprockets myself, but spent $20 (US) by having a local motorcycle dealer's shop cut the old chain and rivit on the new one. I didn't want to spend the money on the tool to do it myself.
1999 Trophy 1200
2002 Harley Heritage Springer
2010 Street Triple
Tom Herold is offline   Reply With Quote
Old 10-12-2008, 02:59 AM   #8 (permalink)
10-Ring's Avatar
Next question. Do you see much/any difference in chain lubes? I have been using Bell Ray. That stuff goes on like a mixture of glue and silly putty. It's so thick and stiff that I wonder if it's able to do it's job, not to mention that it makes a caked on mess out of the chain and sprocet.
Old 10-12-2008, 03:21 AM   #9 (permalink)
Personally I stay away from the chain wax type lubricants, they seem to attract a lot if grit and pile up under the front sprocket cover.
I've used the stuff from Motul and Repsol with good results and my last chain went 22k miles before I replaced it.
Cleaning it with kerosene, diesel fuel or an aftermarket type chain cleaner is important too. Avoid WD-40, it's a penetrating type lubricant and can severly effect the O or X rings ability to keep the grease in, which shortens chain life.
1999 Trophy 1200
2010 Street Triple
Old 10-12-2008, 12:18 PM   #10 (permalink)
10-Ring's Avatar
Spocket Center has a chain and sprocket set for $186, that doesn't sound too bad. I guess I'll get that ordered up and try to mount it next Saturday.
Advice Please. - chain and sprockets lovecuba Hinckley Classic Triples 12 01-14-2008 05:22 PM
Cam chain slipper guides...any advice Pipes Daytona Deliberations 2 02-12-2006 06:31 AM
What chain Speed four advice needed Ozz Triumph SuperSports 1 11-23-2005 05:35 PM
Cam chain slipper guides...any advice Pipes Maintenance & Workshop Talk 4 10-29-2005 01:11 PM
Chain/Sprocket worn out ... advice Sprintster T3 Sport / Touring Forum 17 04-05-2005 07:34 PM
