Clutch Cover Gasket Leak '01 ST 955 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-08-2008, 06:08 PM   #1 (permalink)
Favourite Bike: '01 Sprint ST
Was out for a ride this last Sunday, and noticed a puddle of oil under my bike when I stopped on the way home. Got the bike home, oil level looked normal, pulled the fairings off and cleaned all the oil off the engine. Let it run for a few minutes while on the center stand and could not find the leak.
Rode it to work the next day and the belly pan was covered in oil again. Turned out it was just the clutch cover gasket ($15 at the local dealer). Just wanted to share some pics of what a mess it makes. Have just over 33k miles on the bike. Seems a little early to be having this kind of failure.
Nathan
dart330 is offline   Reply With Quote
Old 10-09-2008, 08:38 AM   #2 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Thanks dart,
good informative post good photos too.
Thanks DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 10-09-2008, 01:29 PM   #3 (permalink)
Favourite Bike: Sprint RS 2000
Other Motorcycle: Yamaha YZF1000
Funny same thing happened on my RS 2000. Owned it for a couple weeks and noticed oil coming from all around that gasket. Was a pain to clean both sides perfectly before putting on the new gasket.
Always use something like 1194 liquid gasket. You'll be happy you did.
Regards,
Stan
sc1966 is offline   Reply With Quote
Old 10-09-2008, 01:46 PM   #4 (permalink)
oldndumb's Avatar
We have a difference of opinion here. I strongly advise against using gasket sealants.
Oldndumb
Caveat lector
Old 10-09-2008, 02:33 PM   #5 (permalink)
Favourite Bike: Velocette Clubman
Calliway's Avatar
Other Motorcycle: 2007 Bonnie Black Cafe
Extra Motorcycle: 77 GS400
Yes! These arent old Chevy 350's where you gooped everything up then slapped it together. Proper torquing pattern and a properly fit gasket should seal it up withouth the goop......
Torquing pattern: Start in the middle and work your way our clockwise in a spiral. That always works for me. Some do a criss cross x pattern as well.
Calliway is online now   Reply With Quote
Old 10-09-2008, 07:58 PM   #6 (permalink)
The stuff I recommended is thin and my local Triumph dealer
said to use it. I learn first hand, the first gasket I replaced started to leak again and I had to buy another. After using the 1194 threebond it's dry as can be. No more leaks. I did the proper pattern and torque the first time also. I've worked on every bike I've owned and am a certified Aircraft Mechanic, I know it's not a Chevy small block.
Stan
Old 10-09-2008, 08:26 PM   #7 (permalink)
oldndumb's Avatar
Whoopie! I have an A&P ticket also, with a few pluses to add to that. So what?
Use what you want, but don't get offended when you opine and others do not agree. After all, it is a forum made up of opinions, and I did say we have a difference. I certainly did not expect to change your mind.
BTW, if the first cover leaked, the proper procedure would have been to true the mating surface. Maybe your difficulty cleaning the old gasket material off was due to a previous install with sealer because of a warped cover.
But, your bike, so do as you please.
And, although it was not my post, even I could figure out that the 350 mention was just rhetorical.
Oldndumb
Caveat lector
Old 10-10-2008, 01:02 AM   #8 (permalink)
Wow, I never expected so much response to my thread.
I am not going to take any of your advice as I was lazy and dropped it off at the dealer .
I have no idea if they used any sealant or not, only time will tell if the gasket holds or not.
I'd be happy to get at least another 33k miles out of the new gasket.
Nathan
Old 10-10-2008, 01:11 AM   #9 (permalink)
Try not to be a smuck. I was trying to state that I do know what I'm doing (in this case) and would never treat any bike like a crappy old slapped together clunker. I was just stating my opinion also. I bet you got your ticket. What did you work for Eastern ? Probably live in South
Florida, now I get it. Take it light !
Stan
Old 10-10-2008, 02:06 PM   #10 (permalink)
Favourite Bike: '02-Sprint ST
johnny's Avatar
Other Motorcycle: '06 Kawi KLR-650
Cool
...Im not touching this one. /-;
johnny is offline   Reply With Quote
Clutch Cover Gasket Needed ToeCutter66 Twins Technical Talk 6 08-20-2008 02:46 PM
oil leak at value cover gasket RT Twins Technical Talk 14 01-15-2007 12:45 AM
valve cover gasket leak Grigsby Twins Technical Talk 12 09-30-2006 06:58 PM
Leak from clutch cover DwarF Speed Triple Forum 2 08-26-2005 02:21 PM
Clutch cover oil leak TJSpeedmaster Triumph SuperSports 1 07-21-2004 11:14 PM
