Anyone do there own oil changes? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-06-2008, 04:17 PM   #1 (permalink)
Favourite Bike: 2000 Sprint
skos's Avatar
Other Motorcycle: 04 Road King
Extra Motorcycle: 07 YZ450F
Just did mine & put in the 3.2 liters wet fill. However my oil window does not show anything? I did fill the oil filter 1st before installing.
Any ideas? Should it not show about ½ way?
Always Pay it Forward!
skos is offline   Reply With Quote
Old 09-06-2008, 04:53 PM   #2 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
I have an '04 with a dipstick instead of a window, but...
My old Kawasaki had a sight glass, & it was nearly impossible to see the level when it was full. Low was at the bottom of the glass, full was at the top. Half a quart down was the easiest to see, as that put the oil level right in the middle. After I had gotten used to it, it became very easy to see whether I was looking at the blank window or at oil, but I really had a hard time telling the difference in the beginning.
Cheers, HTH,
-Kit
Old 09-06-2008, 05:33 PM   #3 (permalink)
Favourite Bike: '00 Sprint RS 955i
pelon717's Avatar
Other Motorcycle: Suzuki DR125 Thumpette
You're still low. Even with prefilling the filter you may be around 6/10 or 7/10 of a liter low. It should take close to 4 L total and I can't imagine the filter holds more than around 4~5 oz (apx 0.15L)
Try adding more in small increments, run the motor to circulate and recheck the level.
It is a puzzling thing. The truth knocks on the door and you say, "Go away, I'm looking for the truth," and so it goes away. Puzzling.
-Robert M. Pirsig
pelon717 is offline   Reply With Quote
Old 09-06-2008, 05:34 PM   #4 (permalink)
Favourite Bike: 10 Street Triple
Other Motorcycle: 99 Trophy 1200
Don't take this wrong, but I've gotta ask; do you have the bike on the center stand or at least held level?
If she's on the side stand on these bikes it won't show anything in the window. I did a change recently and wound up over filling by half a quart because I wasn't waiting long enough for the oil to drain into the sump completely........ still working on that patience thing....
1999 Trophy 1200
2002 Harley Heritage Springer
2010 Street Triple
Tom Herold is offline   Reply With Quote
Old 09-06-2008, 06:36 PM   #5 (permalink)
Favourite Bike: Triumph 955 RS
BlewBayou's Avatar
Other Motorcycle: Honda Valkyrie
I was just thinking the same thing tom.
BlewBayou is offline   Reply With Quote
Old 09-08-2008, 02:08 AM   #6 (permalink)
skos's Avatar
Neither
Neither. I was holding it from the right/brake side straight up.
I called my local Triumph dealer over the weekend and asked the service dept. They seem to think I am good.
My issue is why do you have a window if it does not serve any purpose. I agree I believe I am still low.
Question, those of you with sight windows. Are you half way or about ¼ from bottom?
Old 09-08-2008, 02:15 AM   #7 (permalink)
Favourite Bike: 99 & 00 Sprint St
PhxMan's Avatar
Other Motorcycle: 2002 Daytona 955i CE
Extra Motorcycle: 2007 675D Track Bike
Usually about half way with bike on level ground and on center stand. I am trying to remember how much oil I normally put in and it seems about 4 liters. Jeff
PhxMan is offline   Reply With Quote
Old 09-08-2008, 09:28 AM   #8 (permalink)
pelon717's Avatar
The window does serve a purpose. There's a 'low' mark and a 'high' mark. Obviously, it's supposed to fall within. I did an oil & filter change yesterday on my '00 and 1 gallon (3.79 litres) put it right on the high mark.
I'd be wary of any service dept that says it's ok if you don't see oil in the sight gauge with the motor off and the bike in an upright position.
You're probably not low by much but I still wouldn't ride without it showing within the min~max range. BTW- the pre 2002 motors hold around 1/2L more than the 2002+ 955 motors. Where did you get the 3.2L number?
-Robert M. Pirsig
Old 09-08-2008, 10:37 AM   #9 (permalink)
Favourite Bike: Suzuki V-Strom DL-650
Tri-oomph!'s Avatar
Other Motorcycle: Sprint ST 1050
Extra Motorcycle: I'll take a dozen!
Can't speak for the older Sprints but my 07 Ninja 650R was half a quart off from what the owners manual said. The sight glass doesn't lie.
Tri-oomph! is offline   Reply With Quote
Old 09-08-2008, 11:36 AM   #10 (permalink)
Favourite Bike: Velocette Clubman
Calliway's Avatar
Other Motorcycle: 2007 Bonnie Black Cafe
Extra Motorcycle: 77 GS400
I thought the older Sprints held more oil then the new ones. 3.2L is the wet fill for an 05+
Calliway is offline   Reply With Quote
