Fuel Tank Sucks - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports Motorcycle.comSportbikeTrackGear
Old 08-22-2008, 09:07 PM   #1 (permalink)
Favourite Bike: 07 Sprint (ABS)
Fuel Tank Sucks
Any one with ideas on this.
After about 12km ride, stopped for gas. Had trouble lifting the gas cap. the tank had sucked a vacume somehow.
Obviously a longer ride it would have started to cause me some problems.
Looking for thoughts on fixing it.
Thanks
Kremin
kremin is offline   Reply With Quote
Old 08-22-2008, 09:15 PM   #2 (permalink)
Favourite Bike: 2002 Sprint ST
deller4210's Avatar
Sucking gas tank
You might have a pinched vent hose
deller4210 is offline   Reply With Quote
Old 08-22-2008, 09:51 PM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
+1 Deller
I would say that is almost definitely what the problem is.
You will need to lift the tank and check if the clear plastic vent tube is not crushed.
I bet that it is.
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 08-22-2008, 10:47 PM   #4 (permalink)
Thanks will check out the the vent tube, Have not had the tank off for a long time so don't expect the hose to be kinked but the weather has been mega crap so perhaps there is a bit of dirt there.
thanks for the help
Cheers
Kremin
Old 08-22-2008, 11:35 PM   #5 (permalink)
DaveM's Avatar
thanks for the help
Cheers
Kremin
Also a distinct possibility.
Your fellow countryman and friend of mine "iceman" experienced the same thing as you describe on his 2005 1050 Sprint.
cheers,
DaveM
My current album;
Old 08-22-2008, 11:50 PM   #6 (permalink)
Checked out the tube, no dirt but the tube was squashed where it and all the others go down behind the waterpump.
How are you supposed to get these back down there?????? Have got the airbox drain and one other in Ok. cannot get the other two to fit whatever I do.
Old 08-23-2008, 04:57 AM   #7 (permalink)
Favourite Bike: 06 Sprint ST ABS red
iceman's Avatar
..... mine were kinked where they connect to the tank - I suspect the tech routed them incorrectly when putting the tank back on after the service.
Just had a look at mine - they are very tight where they go down beside the water pump - dont know how to squeeze the last one in without removing the coolant hose.
Perhaps run it behind the water pump for now until the next service?
Grant
iceman is online now   Reply With Quote
Old 08-23-2008, 05:54 AM   #8 (permalink)
One way valve problem
This happened to me when I was on holiday in France, on inspection I found that the one-way valve attached to one of the vent tubes had blocked (hence the vacuum in the tank). It was a 5 minute job to remove it and blow out some water and debris that was causing the issue.
I hope this helps.
Tony.
Hornet01uk is offline   Reply With Quote
Old 08-23-2008, 07:24 AM   #9 (permalink)
I hope this helps.
Tony.
Thanks for that Tony, will check it tomorrow.
Regular fuel tank vs. reserve tank question Newbritrider Twins Technical Talk 17 07-06-2011 02:55 AM
how many god***** litres of fuel in a ****** tiger fuel tank pastitoo Tiger Chat 25 02-15-2010 02:30 PM
Fuel Tank Gas Cap Mod???? BigmaninSENC Twins Technical Talk 0 07-30-2008 12:34 AM
Fuel Tank paint clogging fuel filters on Adventurer Hinckley Classic Triples 3 03-09-2005 04:41 PM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 10:23 AM
