BikeBandit
Old 04-02-2005   #1 (permalink)
Okay, not having the manual, I figured how hard can it be....
Replacing the pads on my ST, have the top "hat" bolt off, have both through bolts out, but still the caliper won't come off. There is a post at bottom, between the pistons that won't allow clearance to pull the calipers free from the rotor.
What now? This post has a nut at its base, am I supposed to undo this little guy?
Thanks,
Daniel
"Dreaming of falling asleep, again"
my piccys
DragonDan is offline   Reply With Quote
Old 04-03-2005   #2 (permalink)
I just did this on an 02, hope there isn't much difference. There are two bolts that hold the caliper on and two socket head retainer pins that keep the pads in place. I have a the Triumph hugger which becomes part of the chaingard that needs to have the screws removed to make things easier. Don't have to remove it, just get it out of the way. Also take anything that binds the brakeline which in my case was a plastic cover in the chaingard. I loosen the retainer pins then take the bolts that hold the caliper on out. At that point it comes right up. Unscrew the pins with my fingers and out come the pads.
I think there is a bit of chinese puzzle work to get it to move it about. The key for me was just getting the chaingard off so the brakeline was free to move. I've heard a couple guys talk about taking off the tire, that was not necessary for me.
Hope this helps.
[ This message was edited by: rodneybrown on 2005-04-03 08:20 ]
Universal Laws of MC Forums
1. Just because the engine is on and the wheels are turning doesn't mean you're "riding".
2. The bike you ride and the farkles you buy have no correlation to how good a rider you are.
3. The ignorant can be enlightened, but the stupid just drive on forever.
rodneybrown is offline   Reply With Quote
Old 04-03-2005   #3 (permalink)
Yup, that did it. I was just not expecting to pull it from its mounting brackets. Was easier than I expected.
Thanks RB :-D
my piccys
Old 04-03-2005   #4 (permalink)
Thanks RB :-D
my piccys
Brake pad replacement question NotSoFast Sprint Forum 4 05-01-2007 10:15 AM
Front Brake Pad Replacement T100Aust Twins Technical Talk 8 09-04-2006 06:30 PM
Brake Pad Replacement -- Speed Four sangsters Modifications & Workshop Talk 0 05-02-2006 08:21 PM
Brake Pad Replacement 2trumpets Hinckley Classic Triples 5 07-21-2005 02:33 PM
Rear Brake Pad(s) Replacement Trophy 8 06-08-2004 01:13 PM
