The Easiest Gps Mount Ever - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew BonnevilleHonda Powersports SportbikeTrackGear
Old 07-17-2008, 03:47 PM   #1 (permalink)
Favourite Bike: SPRINT ST 1050
I have seen many ideas how to mount your GPS to your bike, all very good. Like many of you I have a very useful car GPS unit which I wanted to try and use on my bike. I have the Garmin 250 and have come up with a very simple solution.
I removed one of the handlebar allen bolts and replaced it with another identical s/steel cap head with a 3.3mm hole and 4mm thread tapped into the center of the bolt to a depth of approx 4mm. I then re-torqued the bolt back in its original position and screwed a short piece of 4mm s/steel which I had welded a 17mm s/steel ball bearing to the one end and cut a 4mm thread in the other.
Finally used some nut lock to tighten in position..job done, the existing cradle and GPS simply pushed into position.
I have stuck a pad (not on pics) on the rear of the GPS and with a simple D clip and cord used as a safety wire just in case it fell off however this has been in place and tested over rough ground and never fallen off!
The Easiest Gps Mount Ever-cimg3060.jpg   The Easiest Gps Mount Ever-cimg3061.jpg   The Easiest Gps Mount Ever-cimg3062.jpg
mf51y is offline   Reply With Quote
Old 07-17-2008, 05:04 PM   #2 (permalink)
Medic09's Avatar
Looks quite nice! Subtle.
Mordechai Y. Scher
Santa Fe, NM
'76 Trident T160 (rebuilding)
'78 Honda CB750K
'07 aprilia Caponord
Medic09 is offline   Reply With Quote
Old 07-17-2008, 05:24 PM   #3 (permalink)
Favourite Bike: 2008 BMW R1200GSA
Groucho's Avatar
NICE.
"When in doubt, gas it. It'll either solve the problem, or remove the suspense."
Groucho is offline   Reply With Quote
Old 07-17-2008, 08:24 PM   #4 (permalink)
Croak's Avatar
Good work. You essentially re-created a Telferizer mount.
Croak is offline   Reply With Quote
Old 07-18-2008, 08:40 AM   #5 (permalink)
ST
Favourite Bike: R3
ST's Avatar
Other Motorcycle: 1050 tiger
Ram mounts do a similar version with a hard rubber ball.
its very strong and works in the same way and can be used in conjunction with a clamp so you han adjust heights and angles etc. you fit a ball to the back of your gps so its very adjustable. I considered a home made version like yours but considered the fact if it broke ive lost my GPS so opted for a tried and tested manufacturer.
i used it with a tomtom rider as the original fittings were dreadfull.
ST is offline   Reply With Quote
easiest way? crashcrawford Maintenance & Workshop Talk 8 02-10-2007 11:11 AM
Easiest motor I ever pulled... Thrux-ton-up Club Cafe' 28 11-25-2006 01:30 PM
Best/Easiest bar ends for Rizomas...? DaBeav Club Cafe' 5 07-19-2006 04:14 PM
Easiest Mod doctorjay Twins Talk 19 06-11-2006 07:56 AM
Easiest way to Increase Power Edelin Twins Talk 10 03-02-2006 06:06 PM
