Old 07-17-2008   #1 (permalink)
The Easiest Gps Mount Ever
I have seen many ideas how to mount your GPS to your bike, all very good. Like many of you I have a very useful car GPS unit which I wanted to try and use on my bike. I have the Garmin 250 and have come up with a very simple solution.
I removed one of the handlebar allen bolts and replaced it with another identical s/steel cap head with a 3.3mm hole and 4mm thread tapped into the center of the bolt to a depth of approx 4mm. I then re-torqued the bolt back in its original position and screwed a short piece of 4mm s/steel which I had welded a 17mm s/steel ball bearing to the one end and cut a 4mm thread in the other.
Finally used some nut lock to tighten in position..job done, the existing cradle and GPS simply pushed into position.
I have stuck a pad (not on pics) on the rear of the GPS and with a simple D clip and cord used as a safety wire just in case it fell off however this has been in place and tested over rough ground and never fallen off!
mf51y is offline   Reply With Quote
Old 07-17-2008   #2 (permalink)
Medic09's Avatar
Looks quite nice! Subtle.
Mordechai Y. Scher
Santa Fe, NM
'76 Trident T160 (rebuilding)
'01 Sprint ST
'78 Honda CB750K
Medic09 is offline   Reply With Quote
Old 07-17-2008   #3 (permalink)
Favorite Bike: 2008 BMW R1200GSA
Groucho's Avatar
NICE.
"When in doubt, gas it. It'll either solve the problem, or remove the suspense."
Groucho is offline   Reply With Quote
Old 07-17-2008   #4 (permalink)
Favorite Bike: '99 Tornado Red Sprint ST
Croak's Avatar
Good work. You essentially re-created a Telferizer mount.
Croak is offline   Reply With Quote
Old 07-18-2008   #5 (permalink)
ST
ST's Avatar
Ram mounts do a similar version with a hard rubber ball.
its very strong and works in the same way and can be used in conjunction with a clamp so you han adjust heights and angles etc. you fit a ball to the back of your gps so its very adjustable. I considered a home made version like yours but considered the fact if it broke ive lost my GPS so opted for a tried and tested manufacturer.
i used it with a tomtom rider as the original fittings were dreadfull.
ST is online now   Reply With Quote
easiest way? crashcrawford Modifications & Workshop Talk 8 02-10-2007 10:11 AM
Easiest motor I ever pulled... Thrux-ton-up Club Cafe 28 11-25-2006 12:30 PM
Best/Easiest bar ends for Rizomas...? DaBeav Club Cafe 5 07-19-2006 03:14 PM
Easiest Mod doctorjay Twins Talk 19 06-11-2006 06:56 AM
Easiest way to Increase Power Edelin Twins Talk 10 03-02-2006 05:06 PM
