I do not know if a 2000 is made as a 2004 but there is 2 pinch bolts on the right side when you are facing the bike. I would imagine since you took care of them if you were able to unscrew the axle.
Make sure the pinch bolt are loose and just pull the axle. I just did that a few dys ago. The other problem possible is when your forks are not in line. The axle may be very hard to push in or pull out in that case.
If none of the above, you have a mystery for me now.
In doubt, crank the throttle.
