Are you riding it, THEN it misfires and stops......or is it just idling on the stand????
Can you ( very carefully) feel which cylinder ( use a thick rag, or a very thick oven glove, and touch each downpipe......for a SPLIT second!!!!!! BE EXTREMELY CAREFUL, YOU CAN GET BURNT) you should be able to feel which one is colder than the others, that's the one thats misfiring.
Then you can check the plug /cap/ etc maybe it needs cleaning or a new plug...or maybe it's had the dreaded " water in the spark plug well" and corroded one plug.........yes, this does happen with the Sprint's...
