The Triumph GPS connector is constant power. it is a hold over from earlier GPS technology and is not appropriate for the Zumo or any other unit with an internal battery and auto off feature.
Air_Bob, you are correct that an inline switch will work, but you are still negating the auto off function of the unit.
It is designed to allow you to maintain your current trip status if you power the bike off, say for gas or a meal. The way it works is that when you switch the ignition off it will automatically switch over to internal battery and present a screen asking if you want to stay on internal power. You either select 'yes' or 'no'. If you just walk away without making a selection, it shuts itself off after 15 seconds.
Why do you think an additional switch is better than that?
Oldndumb
Caveat lector
