Originally Posted by Panthers_Den
hmm.. cool.. are the adjustable hook style's any good? Any idea what size ours is? I just may have to buy one, I hate the Triumph tools, they suck.
Pros and cons for the adjustable ones.
By design, they tend to allow a 'wrapping' motion around the nut which makes it a bit more secure, and also lets them be used for more sizes. Being forged, you can let a gorilla use them.
All of the ones I have used were in areas that tool thickness was not a factor. Since they are thicker than the fixed size designs, they could be difficult to fit in place on a Triumph eccentric.
I believe that you can expect the flat designs from McMaster-Carr to be manufactured from stronger material than the T factory tool.
As to the factory tool size, I scale it at 4.60in/117mm.
