AdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 05-17-2008   #1 (permalink)
Favorite Bike: All of them
Other Motorcycle: Suzuki DR 350
Air and your tires
This has probably been covered ad nauseam but I found a website a week ago that was pretty interesting so I tried some of his suggestions on my bike and it seems I've been running my tires right for all these years, cars and bikes.
Do about 10-15% cold below the manufac suggested and at running temps its right on the money at heat within one to two pounds based on the outside temps.
My stock rear Bstone BA 020 run at 5 lbs under at 30 to 45 degrees heats up to 42 lbs on a 70 degree day after about 30 miles.
You check them cold at 55 degrees and they'll be one to two pounds higher so ymmv as to how anal you are on your tire lbs.
Cheers!
My other torque wrench is a hammer.
4N099 is offline   Reply With Quote
Old 05-17-2008   #2 (permalink)
Favorite Bike: Blue 06 st sprint ABS
monkinwitz's Avatar
Air Checkers
I put aircheckers on the bike and just a look at the cap tells me what the pressure is you can buy them for different pressures i run 32 front and 36 rear,they are green when your pressure is correct and yellow if you have lost 3 or 4 pounds and red when you are down about 5 to 9 pounds they are a good investment .
TAKE NO PRISONERS
monkinwitz is offline   Reply With Quote
Old 05-17-2008   #3 (permalink)
That takes all the fun out of it.
Tires 50/50 or 60/40? Mille44 Tiger Chat 21 08-09-2007 06:19 PM
tires pz1 Twins Technical Talk 1 06-19-2007 09:35 AM
Tires mdbauer Hinckley Classic Triples 7 11-09-2005 03:01 PM
Tires...? FattRat Twins Talk 6 09-11-2005 08:27 AM
Which tires to buy? AVATR Sprint Forum 46 04-29-2005 07:22 PM
