Motorcycle.com
Old 05-15-2008   #1 (permalink)
sodapop's Avatar
Removing tank pad help
I'm wanting to change out my tank pad. I have one of those Pro-Grip ones which I'd like to replace. Anyone ever remove one of these? I'm thinking of liftiing a corner and going at it with a hair dryer to soften it and pull it back. Not sure what kind of residue will be left and if taking it off will ruin the clear coat/paint underneath. I won't do it if that's the case. Will just have to live with what I originally put on. Anyone have any experience with this?
Thanks ahead.
Jess
1997 Blue Suzuki GSF1200 Bandit (trade in)
2006 Sunset Red Triumph Sprint ST
sodapop is offline   Reply With Quote
Old 05-15-2008   #2 (permalink)
Favorite Bike: Sprint 1050
ralphus's Avatar
Thanks ahead.
The technique you propose sounds OK just pull it off gently so you don't take any paint with it. Use kerosene to remove the residue followed by soapy water and polish.
ralphus is offline   Reply With Quote
Old 05-16-2008   #3 (permalink)
Favorite Bike: 2002' Sprint RS
Other Motorcycle: 1995 Honda XR 650L
I've removed some pretty nasty adhesives from painted surfaces, I work in a glass shop and when people break windows they like to use duct tape or Tuck tape to stick a garbage bag over the hole. First off, I've used solventto remove adhesive before and it did dull the clear coat, although I'm pretty sure a little wax would bring the shine back.
If I were to remove a tank protector I would definitely use a heat gun on low setting to soften the adhesive, start on an edge and peel slowly. A little trick I've learned along the path of removing sticky things is that if you pull on the material at about a 45 degree angle away from center instead of pulling across center and be gentle and patient the results are much better. I think this is because you stress the material less and cause less separation. No matter how careful you are you will always leave some adhesive behind. For the left behind adhesive I would try spraying sudsy ammonia on the left overs and let it sit for awhile. The adhesive should soften and be easily removable at this point. If not try a citrus based cleaner like Goo Gone.
Personally, I wouldn't use a solvent but I can pretty much guarantee that it will both remove the adhesive and dull the finish.
Give me twisties!!
Curt955i is offline   Reply With Quote
Old 05-16-2008   #4 (permalink)
Favorite Bike: Triumph Sprint ST
Vlermuis's Avatar
Other Motorcycle: Hyosung Aquila GV650
I agree with the hair dryer. For the remaining adhesive, I have used penetrating aerosol oil like Q20 with excellent results.
Vlermuis is offline   Reply With Quote
Old 05-16-2008   #5 (permalink)
Favorite Bike: Blue 06 st sprint ABS
monkinwitz's Avatar
Just use this
CRC thats about all its good for
TAKE NO PRISONERS
monkinwitz is offline   Reply With Quote
Old 05-16-2008   #6 (permalink)
Favorite Bike: 06 Sprint ST ABS
Garyhjd's Avatar
Other Motorcycle: Legend TT
Try using wd-40 to take the residue off. Won't harm the finish and I bet you already have some.
Garyhjd is offline   Reply With Quote
Old 05-16-2008   #7 (permalink)
Favorite Bike: 2005 Caspian Blue ST
Calliway's Avatar
CRC is a brand and they make brakekleen, Carbkleen, intake cleaner etc.... which product are you referencing?
Calliway is offline   Reply With Quote
Old 05-16-2008   #8 (permalink)
Sodapop,
I'd recommend against the heat gun. After all, it's a plastic tank!
I would try cutting the doublestick with a piece of fishing monofilament, then cleaning it up with WD-40.
Alteratively, you could use some dental floss.
I used the above technique to remove all the name placards from my Tundra.
Take your time.
Good luck!
pushr0d is offline   Reply With Quote
Old 05-16-2008   #9 (permalink)
monkinwitz's Avatar
Crc
Yep sorry about that chief crc 5.56 lubricating oil
TAKE NO PRISONERS
Old 05-17-2008   #10 (permalink)
Favorite Bike: All of them
Other Motorcycle: Suzuki DR 350
Hair dryer on high held about 9 inches away is plenty of heat, work small sections until you peel the offending pad.
Goo Gone removes the residue.
Go to Lowes or Home Depot or something similar and get some diaper soft cleaning cloth to work the Goo Gone and get some Meguires #9 swirl remover or #6 cleaner wax. Use the soft cloth for everything.
Wash the area down with water and dry after you goo gone it and hit the area with the Meguires.
My other torque wrench is a hammer.
4N099 is offline   Reply With Quote
Removing Tank? Razz11 Triumph SuperSports 3 03-16-2008 10:38 PM
Removing Tank ? zugspitz Twins Technical Talk 6 07-24-2007 03:47 PM
Removing stickers on tank? FlyBri Twins Technical Talk 8 07-03-2007 02:50 AM
Removing tank - how to? YourOldNemesis Speed Triple Forum 3 08-08-2006 11:06 AM
Removing gas tank Kegel Triumph SuperSports 5 10-10-2005 06:41 PM
