Motorcycle.com
Old 05-14-2008   #1 (permalink)
Favorite Bike: 2007 Triumph Sprint ST
Inspector Vijay's Avatar
Other Motorcycle: Suzuki Bandit 1200S
Shifting problem
I'm having a bit of trouble finding neutral on my 07 Sprint. This is a new development; it didn't use to happen. The transmission was a bit stiff when the bike was brand new, but had eased up beautifully. Now, I have to say a little prayer before delicately tapping down with the middle of my boot to find neutral. (Very stressful when stopping to pay tolls etc., as you can imagine.) Booting up from first is even trickier. All other gears work fine, except for the occasional heavy clunk when going from neutral to first.
What do you think is causing the problem? Is this something that the dealer can resolve with a new chain and sprockets and maybe some good oil, or is there a bigger issue with the transmission?
It always gets into neutral eventually. But I would still like this to be effortless, like on my Bandit.
Inspector Vijay is offline   Reply With Quote
Old 05-14-2008   #2 (permalink)
Favorite Bike: 08 Pacific Blue Sprint
shifting
I noticed a significant improvement as soon as I got the break-in oil out of my 2008 Sprint. Clearly oil choice makes a difference. I used the zillion dollar/gallon Triumph oil which seems to work very well. The other thing I notice is I need to keep the engine speed up while shifting. When I am commuting along in traffic I notice the transmission is much more cranky if I shift under 3000 rpm. Also, the transmission is very cold blooded. On cold mornings, I need to be real careful for the first few miles untill things warm up a bit. This may suggest a sensitivity to oil viscosity if you are using something thinker than the Triumph stuff.
jpm
riptide262 is offline   Reply With Quote
Old 05-14-2008   #3 (permalink)
Favorite Bike: 2005 Caspian Blue ST
Calliway's Avatar
Neutral is never an easy find on the Triumoh. Sometimes I have to do a little rock when its cold but other then that the transmissions are great. Good feedback which some may mistake as clunky.
Calliway is offline   Reply With Quote
Old 05-14-2008   #4 (permalink)
Favorite Bike: 07 Triumph Sprint ST ABS
F4sSprintST's Avatar
Other Motorcycle: 06 Suzuki 650 DR
Okay, this doesn't solve your transmission problem, BUT.....
  1. Buy a Toll Pass Tag
  2. Shift into neutral while you are still rolling up to the stop, gives you more time to do it
Got 6 Pots?
- Tokico 6 pot calipers & Gafler HH pads
- PowerBronze Shield & Pazzo levers
- Trident Exhaust, TOR & 18T front sprocket, speedo healer, 2k bars
- Skyking Frame & MV rear axle sliders, Clear Alternatives smoke tailight, 6k HIDS
F4sSprintST is offline   Reply With Quote
Old 05-14-2008   #5 (permalink)
Favorite Bike: 2002 Sprint ST
Remember, these are straight cut and not bevel cut gears and if they meet tooth on you will get what you are describing. It's just the nature of the hardware and I doubt anything is wrong, you just haven't experienced this before.
Just a little roll forward or back should get things out of alignment.
Old 05-14-2008   #6 (permalink)
Newbie
Favorite Bike: 2000 Sprint RS
Other Motorcycle: 2008 YZ450FX
Maybe your clutch needs adjusting.
feirmeoir is offline   Reply With Quote
Old 05-14-2008   #7 (permalink)
Favorite Bike: 07 Sprint ST
I started to notice this also with my 07 around 5500 miles. Changed the oil and adjusted the clutch cable, and neutral is a breeze to find now. I noticed that the clutch wasn't completely disengaging before I adjusted the cable.
Barndoor is offline   Reply With Quote
Old 05-14-2008   #8 (permalink)
Favorite Bike: 06 Sprint ST ABS red
iceman's Avatar
... Clutch adjustment is a possibility.It happened to me a couple of years ago - turned out there was a bit too much freeplay and with the lever pulled right in the clutch wasnt disengaged properly.
A quick adjustment and it was all good
Grant
iceman is offline   Reply With Quote
Old 05-14-2008   #9 (permalink)
Favorite Bike: Blue Sprint ST 1050
Pickle Jim's Avatar
Other Motorcycle: GSXR 750 K4 (Deceased)
Your other problem is one of perception.
Your comparing your Sprint Gearbox against a Suzuki and the one thing Suzuki know how to do is build a slick smooth as silk gearbox.
My previous was a GSXR 750 K4 and it's taken me a couple of months to really get used to the box, there's nothing wrong with it, but yo can't compare any other gearbox to a Suzuki.
Pickle Jim is offline   Reply With Quote
Old 05-14-2008   #10 (permalink)
Favorite Bike: 06 Sprint 1050
tubby885's Avatar
Other Motorcycle: 97 Trident 900
Balls
A tip for slicker shifting.
Grease the gear lever pivot.
Disassemble the link rod ball joints and pack them with grease.
All these were dry on my ST now shifting is super slick with no problems finding neutral or any false neutrals.Selecting neutral on the ST requires a precise touch,too much pressure and you can shift through it into the next gear.
tubby885 is offline   Reply With Quote
False Neutrals & Shifting Gear Problem scobell Speed Triple Forum 15 10-14-2007 04:07 PM
gp shifting SPRINGER1978 Club Cafe 19 05-29-2007 12:47 AM
Shifting! Moosey The Rocket Science Forum 5 04-23-2006 05:31 PM
D650 shifting problem mikmoo Triumph SuperSports 4 01-19-2006 06:39 PM
Shifting problem Spooner Hinckley Classic Triples 11 10-08-2004 05:13 PM
