One man's rumble is another's drone, is another's hum, is another's rattle, is another's....well you get the idea.
I don't know if the noises being referred to are all the same, but this is one method of eliminating a possible cause.
First,I need to apologize for not doing a PDF display, but hopefully my words will suffice for the appropriate audience.
When you squeeze the clutch lever, the cable actuates the clutch lifter arm, which in turn actuates the internal lifter piece which then moves the pressure plate. The lifter piece rides in a bearing which is central to the pressure plate.
All manufacturers have machining and assembly +/- tolerances. Sometimes an accumulation of tolerances can affect operations. In the clutch scenario there are several tolerances which may/may not affect its quiet operation.
- The lifter piece bearing bore in the pressure plate.
- The five pressure plate attach bolt bores.
- The lifter piece.
Anyone reassembling a clutch pack should know that they are supposed to verify that the lifter piece is free and does not bind in the pressure plate bearing.
Since the pressure plate has five attach bolts, there are five possible orientations. The significance of this is, due to the accumulation of tolerances, there is one location out of the five that will provide the best alignment of the bearing to the lifter piece. This best alignment will allow the quietest clutch operation.
If this seems familiar to the astute members, it is because it has been posted before.
