As mentioned earlier Triumph recognise that handlebar vibes is pretty serious issue and hence their solution is those elaborate dampers on the bar ends.
This works OK for most people but there are some people out there are still sensitive to vibes coming off the engine such as yourself.
Engine vibes are usually addressed with rubber mounts to dampen out vibes transferred to the frame. Triumph engines are directly mounted to the frame, hence engine vibes are transferred directly to the frame.
You need to dial them out by isolating the handlebars from the engine and frame
(rubber sandwiched between the handlebars and tripleclamp is reasonably effective) or by changing the mass of the handlebars so natural frequencies don't coincide with the engine resonants. Heavier bar ends weights lower the natural frequency of the bar ends while lighter bar ends have the opposite effect.
[/quote]
Good info in that post, thankyou
so putting rubber between the clamps is a easy fix for me, but does anybody make bar ends for triumphs?
