I did not use any silicon/RTV/sealant on the cam cover gasket; the gasket stayed attached to the head when I pulled the cover, & I tend to operate on the "less is more" theory when dealing with goop like that. (I certainly would have used it if the gasket had not stayed attached, though.)
I had *an* oil leak(?) before, but *this* oil leak began immediately after I checked my valves & appears to be coming from the upper rear part of the head. (At least all my valves are in spec!
I am looking for a used alternator cover to replace mine with, but I'm a bit short on cash after my vacation & haven't replaced it yet. (Ouch!!! Those seals & gaskets are pretty pricey too!) As far as the breather seal, though, there were maybe 2 or 3 drops of oil in my airbox last I looked. There is not a significant amount of motor oil moving through there.
Here's something: I noticed today that there's oil around the dipstick. I've seen it there before, but mostly wrote it off to being sloppy when refilling. But I've cleaned that area up & been careful not to be sloppy lately, & it came back anyway. Now that I'm thinking about this, I don't think there's an o-ring on my dipstick. I really don't know if that could account for all my oil loss, but maybe some of it?
Cheers,
-Kit
