Starcom Glovebox Installation - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-09-2008, 11:23 AM   #1 (permalink)
Favourite Bike: Ducati 916
oxsprint's Avatar
Other Motorcycle: Gas Gas EC300
Extra Motorcycle: Ducati M900
I'm looking for an idiot's guide (with the emphasis on idiot) to installing the unit in the glovebox with as much info and as many photos as possible. Thanks
I can resist everything except temptation
I came into this world with nothing and I've still got most of it left
oxsprint is offline   Reply With Quote
Old 05-09-2008, 01:20 PM   #2 (permalink)
Favourite Bike: 2006 Sprint ST1050
PeirreOBollox's Avatar
The unit sits in the glovebox, using the hook and stick pads supplied by starcom.
cables L-R starcom/Zumo CAB-55 (cell/MP3 audio) cable, centre IPOD audio, right - aux audio. These exit out of a notched hole near the lock hole, and run CCW inside the fairing infils, across the Headlamp and exit near the LHS speedo.
The power and rider/passenger audio cables exit out of a hole in the bottom of the glovebox, in the bottom corner below the notch you can see, with enough slack cable inside to enable me to be able to lift out the starcom if req`d
http://i224.photobucket.com/albums/d...n/P5090002.jpg
though mine now sits much lower than I intended originally so I can get the tool kit back in, so I need to re-stick it.
http://i224.photobucket.com/albums/d...n/P5090001.jpg
but the wiring is outside, underneath around the relays, depending on your locations where you want the audio leads to exit, will determine where and how you run the cables, mine exit on the O/S near the point where the seat/tank/seat fairing meet for the rider, as do the battery minder connector, and the fill tube for the scottoiler (lube tube)
http://i224.photobucket.com/albums/d...n/P5090004.jpg
and exit out by the rear O/S of the grabrail for the passenger, and is zipped tied to the sub frame rail & grabrail. but I`m guessing you may also need 1 x audio extention cable to run the passenger feed to the rear IF you haven`t used the twin audio BKT-01 mounting bracket that sits on the N/S subframe diagonal rail. either way your going to find out if you need additional brackets/cables
http://i224.photobucket.com/albums/d...n/P5090005.jpg
you probably only need to remove the seat, seat fairing (or loosen the front 4 bolts) and the RHS lower fairing to do the install, power is from wiring by the relays, just find 1 that is live when the ignition is on only, though the power wire for the back light is a convienent source
There should be a specific install instructions for the sprint on the starcom website
I accept no responsibility for swearing, drinking, motorcycle riding or your pregnant teenage daughter.
PeirreOBollox is offline   Reply With Quote
Autocom vs. Starcom remlin1 Helmets 3 04-15-2007 11:42 PM
Intercom ??s Autocom, Starcom, IMC ??? Suncoast Sprint Forum 8 01-12-2007 07:14 PM
Motocomm Audioboss vs Starcom 1 vorpal Sprint Forum 11 04-07-2006 02:09 PM
05 Sprint Glovebox Lid Moondog Sprint Forum 2 11-14-2005 07:57 AM
StarCom 1 bowillyard Sprint Forum 9 06-30-2005 03:28 PM
