Gas Leak - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda Powersports Motorcycle.com
Old 05-07-2008, 07:54 PM   #1 (permalink)
Newbie
Favourite Bike: Not Sure
Other Motorcycle: 1995 Sprint
Extra Motorcycle: CBR 600
Gas Leak
I just bought a 1995 Sprint with 8,000 miles on it. Runs Ok on the top end but sluggish on the low and every so often when I park it, it leaks gas out of the airbox. I'm running carb cleaner and its helping with the performance but I can't get my hands around the gas leak, hoses look good. Is something sticking open? Will the carb cleaner do the trick? Replaced plugs and airbox and still have leak.
Mark Anderson is offline   Reply With Quote
Old 05-07-2008, 11:55 PM   #2 (permalink)
Favourite Bike: 06 Sprint ST 1050
02redbird's Avatar
Other Motorcycle: 05 Thruxton 900
Welcome to the Sprint
Mark,
Tons of information here, so you've got a bit of reading to do.
Did you have the tank off? And who did this work?
There are many post about a plastic elbow on the bottom of the tank cracking if you do a search in the sprint forum.
Your leak sounds like the tank is too full and the fuel is expanding, then the fuel should run out the over flow hose? But maybe that hose has become disconnected at the tank.
You should have three small hoses for overflow fluids. Fuel=gas tank, Coolant=Radiator reservior, oil blow-by=Airbox.
Did you buy from a private party, if so, do they want to shed any light on the problem?
Or
Call these guys,
British USA
1210 College Avenue
S. Houston
TX
77587
Tel: 713-944-7951
Fax: 713-946-4829
Where does a 1995 Sprint come from with only 8000 miles?
Eric
"You're going too fast young man. Me? fast? I only look fast."
02redbird is offline   Reply With Quote
Old 05-08-2008, 06:47 AM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Welcome
Hi and welcome to TriumphRat.net Mark.
I think you will find the answers in the T3 forum which is where the carby Sprint guys mostly hang out
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 05-12-2008, 06:01 PM   #4 (permalink)
Newbie
Wink Thanks For The Reply
Hey thanks for the welcome. It seems carb cleaner is doing the trick. Intermittently when I would put the bike on its side stand gas would leak into and out of the airbox. I think lack of maintenance and riding (from the previous owner) was the problem. Still slower than my CBR 600 but I'm not sure all the junk is out of the carb, occasionally sputters on the low end, but running and idling good.
To the question Where does a 1995 Sprint come from with only 8000 miles? From the garage of someone who like to own a bike rather than ride it.
Thanks for the replies.
Old 05-12-2008, 10:20 PM   #5 (permalink)
Favourite Bike: 2000 Sprint RS--Beowulf
seumas's Avatar
Other Motorcycle: 1995 Sprint 900
Hey Mark, come check out the T3 Sport/Touring forum. Look a little further down the main page and you'll see it. You'll probably get more answers there. I'd guess a sticking float or needle. If the carbs overflow they leak into the airbox.
You'll see some posts from KitNYC on this forum. He's also the moderator on the T3 forum. There are a couple of us who have the older carbed Sprints as well as one of the newer models.
"We fight not for glory, nor for wealth, nor honor but only and alone
we fight for freedom, which no good man surrenders but with his life."
seumas is offline   Reply With Quote
Old 05-13-2008, 10:39 AM   #6 (permalink)
Newbie
Question
Thanks for the reply. What is a Franken-Sprint?
oil leak or no? GCA Twins Technical Talk 13 07-06-2007 09:00 AM
oil leak philB Twins Technical Talk 2 01-25-2007 03:55 PM
Anybody else had an oil leak? Yogi The Rocket Science Forum 7 08-01-2005 05:23 PM
OIL LEAK vanpraag Sprint Forum 11 07-21-2005 08:38 AM
Possible Gas Leak? dwheft Twins Talk 2 07-19-2005 07:04 PM
