sprint alternator drive - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Honda Powersports Ontario TourismMotorcycle.comMotorcycle.com Classifieds!
Old 05-07-2008, 04:48 PM   #1 (permalink)
Desperately seeking the little rubber bumpers inside the alternator drive for a '96 Sprint. All the dealers I've contacted say the can't get them.
There's a vibration that increases with engine rpm, and it's gradually gotten worse over the past two years. I don't know if this will fix it, but those rubber bumpers are badly deteriorated.
Any help appreciated.
jgordon is offline   Reply With Quote
Old 05-07-2008, 10:43 PM   #2 (permalink)
I am not sure if this will work in your situation. If you can get some red (high temp) rtv sealant, try putting a dab of it on the old rubber bushings to to build them back up a bit. Let it dry overnight or most of the day then reinstall. Of course the best cure would be to find the OEM parts, but in a pinch this might help alleviate the vibrations at the alternator.
copterdoctor is offline   Reply With Quote
More thinking out loud: Final drive question, why not Belt drive or Shaft drive? rudebwoy85 Speed Triple Forum 13 12-25-2009 08:04 PM
Alternator drive shaft .. help a brother out! mb Hinckley Classic Triples 6 08-20-2007 04:40 PM
Alternator drive - again Jodel Hinckley Classic Triples 9 07-18-2007 09:13 PM
Alternator output on the Sprint TiggerTwo Sprint Forum 4 01-08-2006 11:39 AM
02 Sprint ST alternator problems kelticwolv Maintenance & Workshop Talk 2 11-17-2005 09:10 AM
