BEWARE of K&N oil filters on your Triumph - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
post #1 of 24 (permalink) Old 06-12-2017, 09:53 PM Thread Starter
Main Motorcycle: 2011 Sprint GT
SapperSprintGT's Avatar
So, I never use K&N filters, I've always had great luck with either factory or Hi Flo which I usually buy 4 at a time. I went to use the last Hi Flo filter I had in my garage before a long road trip and when I pulled it out of the sealed box there was a large dent in the side of it. So, without enough time to order more, I reluctantly called around the local parts stores and found only one oil filter specified for use on the Sprint GT, the K&N KN-204 filter. It was expensive, around $17.00 I believe but I needed it and it got the job done.
Just over 2k miles later I'm riding through some back-country roads when out of the very bottom of my line of sight I see the red oil light flicker on and off on my Sprint. I immediately kit the kill switch and coasted to the side of the road where oil was puking out of the bottom of my bike. I looked underneath and it was immediately apparent, the bottom of the oil filter had blown out near the tack welds for the nut K&N puts on the filter for ease of removal. There was oil everywhere, my rear tire was drenched in it, how I did not go down is beyond me, someone was looking out for me.
Without cell service I was very fortunate to have someone stop and take me to the top of the mountain. I called around and unfortunately the only filter available was another POS K&N and it was an hour away. Bob who stopped to help was also a rider and agreed to take me there, I was extremely gracious. An oil filter and 2 quarts of oil later and a can of brake cleaner to clean everything off and I was back on the road.
Lesson learned, K&N oil filters are utter crap. I googled the issue and apparently I'm not alone in having this happen. There is no significant damage to the filter, it didn't bottom out, there are no scrapes anywhere on it and I hand tightened it like I have every filter I've changed in the last 20 something years of doing my own maintenance.
For safety sake, avoid these things like the plague. I still cannot believe I didn't go down and plan on sending an oil sample to Blackstone labs to see what kind of damage I did to it running it momentarily with low pressure. I want to pursue making K&N pay for a replacement engine/transmission since who knows what damage was done and this was clearly a manufacturing defect and a major major safety issue, I could have been killed. Anyone with legal knowledge feel free to chime in or send me a PM as I would appreciate it. I'm guessing I should just hire a lawyer to draft something up and send to them.
I know it looks like there are dents in the side of the filter but that is actually just oil, I'll clean up the outside of the filter and post better photos of the damage and the filter.
Be safe out there!
ID:	481193   Click image for larger version
"Get busy living or get busy dying"
SapperSprintGT is offline
post #2 of 24 (permalink) Old 06-12-2017, 11:12 PM
Main Motorcycle: 2006 Sprint ST
MileHighScottie's Avatar
Other Motorcycle: 2003 Sprint ST (her's)
Extra Motorcycle: 2014 Thruxton (gone)
I had this happen on my Thruxton as well, using a K&N filter. Didn't catastrophically fail but did leak out at the site of the nut.
MileHighScottie is online now
post #3 of 24 (permalink) Old 06-12-2017, 11:19 PM
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2000 Sprint ST
Extra Motorcycle: 1972 Honda CB350K4
Glad you and the bike are ok and duly noted to not use K&N oil filters.
SapperSprintGT likes this.
"You are either on something or onto something"........The Common Man
BRG-BIRD is offline
post #4 of 24 (permalink) Old 06-13-2017, 12:10 AM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
There was a recent thread on Air Cooled Tech Talk forum where an Bonne owner had this exact issue...his engine would not start after replacing the faulty filter. Had it taken apart, found to be oil starved and in need of rebuild. K&N examined the filter and decided to pay out for a new engine...at least they stood behind their warranty as per their website.
Still, these welded nut filters are not worth the risk! Avoid at all cost (which could be your life). A solution in search of a problem as far as I can see.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
post #5 of 24 (permalink) Old 06-13-2017, 05:41 AM
Main Motorcycle: Black '04 Sprint RS
Immoderate Moderator
KitNYC's Avatar
Other Motorcycle: Blue '04 Sprint RS
This just happened to a friend of mine's Speed Triple last month.
Cheers,
-Kit
'04 Sprint RS * Penske 8983 * Traxxion AK20s * Zero Gravity sport touring screen * Oxford heated grips * DGD keyless ignition * Relocated seat lock * Givi saddlebags with custom mounts * Fuzeblocks FZ-1 power block * Adaptiv TPX radar detector * Garmin GPS in RAM Aquabox * Garage door remote * Tokico six pots * Pazzo shorty levers * Voltmeter * Yoyodyne gas cap
KitNYC is offline
post #6 of 24 (permalink) Old 06-13-2017, 10:44 AM
Newbie
Main Motorcycle: 2011 Triumph Sprint GT
Other Motorcycle: 2002 Buell S3T Thunderbol
Extra Motorcycle: 2009 Buell 1125R
Wow thank you for sharing this and i'm glad your situation was not much worse as it could've easily been. I have been using the Hi-flo HF204RC filters for a few years on my former Tiger 1050 and now more recently on my Sprint GT. It has the same style nut for removal which is super handy. Now i'm wondering about the integrity of that filter although i haven't heard of any issues like with the K&N. I always wondered if Hi-flo racing series & K&N were related since the welded nut looks very similar. My girlfriend has a K&N KN138 on her Suzuki SFV650 so i will be inspecting that and possibly swapping it at my earliest convenience.
Metallian is offline
post #7 of 24 (permalink) Old 06-13-2017, 10:52 AM
Main Motorcycle: 2016 Bonneville T120
NN65's Avatar
Other Motorcycle: Honda CD125 Benly
Extra Motorcycle: Jawa CZ360, 1965
Just my 2cc: some users seem to find the welded bit handy for fitting the filter --it should certainly only, if ever, be used to remove the filter, not fit it.
For lack of any alternative in my place, I use a K&N now. It is due for a change next month, I'll check carefully. And replace with an OEM one (just imported 4 of them).
NN
NN65 is offline
post #8 of 24 (permalink) Old 06-13-2017, 01:39 PM
Main Motorcycle: 2015 KTM 1290 SDR
Ferris's Avatar
K&N filters are Hi-Flo with a nut added. KN204 = HF204
Ferris is offline
post #9 of 24 (permalink) Old 06-13-2017, 07:54 PM Thread Starter
I did not use the nut for tightening the filter, as stated in my original post it was hand tightened. I don't have a problem with the filter itself and it has been shown through disection that the filter element and bypass valves are actually well designed. I think the issue stems from the fact that the nut is tack welded onto the casing and the tack welds cause a degradation of the filter housing. Since the Hi Flow units I have used did not have a nut tack welded on I have not had an issue with them.
On a car, no big deal, engines and filters can be replaced but ask yourself, is it really worth risking your life for the ease of removing an oil filter with a wrench or ratchet? This could have been disastrous for me had my rear wheel lost traction due to it being covered in oil.
post #10 of 24 (permalink) Old 06-13-2017, 07:57 PM Thread Starter
Thanks for the information. I plan on changing the filter and oil this weekend and will send an oil sample out to blackstone labs to see what kind of wear occurred. I fear that because most of the oil was actually spit out of the faulty filter I won't get a representative idea of wear through a UOA.
Oil Filters That Fit v2 BonnieBlack Air Cooled Twins Technical Talk 50 06-05-2017 10:25 PM
Anyone use reusable oil filters - metal mesh screen filters ? Asmodeous Tiger 800 - 800XC Mods & Workshop 5 10-23-2015 12:56 PM
K&N vs stock oil filter for 2013 Thrux AllCafe Air Cooled Twins Technical Talk 11 10-19-2015 10:25 AM
Fumoto quick oil drain valve (Long & Boring) Forchetto Air Cooled Twins Technical Talk 36 05-02-2015 09:49 PM
Nightmare Oil Change jalalski Sprint Forum 17 02-24-2015 07:51 PM
