Old 03-09-2005   #1 (permalink)
Bought a leftover 02 RS.....rear plastic fender has a flat surface for a tag, but it's narrower than a tag. Is there supposed to be a factory bracket here??
Old 03-09-2005   #2 (permalink)
yes
2ndSpace is offline   Reply With Quote
Old 03-09-2005   #3 (permalink)
Thank you...
Old 03-09-2005   #4 (permalink)
Same thing happened to me. When I got home with my new '04 RS there was no place to mount a plate. So, I used the bracket that was once on my Ducati (pre-modification) and drilled the rear plastic to accomodate the Duc bracket. Voila! The RS is now the beneficiary of an Italian stem cell transplant. Or something like that.
Bruce19 :wink:
Old 03-09-2005   #5 (permalink)
Danielk - Does your rear fender have the red reflector?
Scottius is offline   Reply With Quote
Old 03-10-2005   #6 (permalink)
Yes, it does, Scottius -
Mine is a leftover 02 RS - original dealer says they don't come with a bracket, and of my two local dealers here in Atlanta, one uses a Kawasaki bracket, and the other a Ducati -
This is kind of bush league of Triumph, but it looks like the fix is easy. What were you going to suggest?
Daniel
Old 03-10-2005   #7 (permalink)
...and thanks, Bruce
Old 03-10-2005   #8 (permalink)
Just making sure about the reflector since that is another flat spot at which to mount your plate. Sounds like you've got it under control.
Old 03-10-2005   #9 (permalink)
Old 03-10-2005   #10 (permalink)
Thanks, Scottius....hopefully the bracket from Kawasaki will be in tomorrow...I'll post as soon as I mount it...maybe the info will help someone else.
Daniel
pictures of my s3 custom license plate bracket tekmoe Speed Triple Forum 4 08-03-2006 11:38 PM
Aluminum LED Tail Light/License Plate Bracket JG Club Cafe 17 06-30-2006 04:47 PM
License plate bracket Aussiekeeper The Rocket Science Forum 2 10-16-2005 11:48 PM
License plate bracket Elmert1200 The Rocket Science Forum 8 06-07-2005 08:04 AM
