Hi Tulkas and welcome to TriumphRat.net and the Sprint forum.
Firstly I am NOT known as one of the technical geniuses on this site but I am sure they will soon be here to help.
Do not be offended if these are too obvious and you have checked them already.
Things I know you could check:
battery terminals are clean and tightly fitted
side stand switch is not damaged
kill switch is not in off position
These bikes are very sensitive to the battery being in top shape.
This seems more of an issue with the newer 1050's than the 955i's.
If you are waiting for more expert advice please do a search as you will find some better explanations than mine.
It appears from my limited understanding that the 1050's seem to suffer from a battery that is possibly a bit short on grunt required to start if not in premium condition.
DaveM
