Originally Posted by mglemans86
Good point about the relays. Are they standard auto shop parts or expensive Triumph parts?
Four of the relays are the same and might be std designs readily available.
Not to imply agreement that it was a good point about the relays, if they are not std you could probably cross reference them to an aftermarket brand if you could find a store with the necessary catalogs. And if you managed to do that, you would have to place them on order, and you may or may not be able to do that depending on if they even carry them in their system.
The 05-06 uses 6 relays. I assume the 07-08 is the same, but I do not have info on them. The starter relay, fan relay, fuel pump relay, and EMS relay are the same and sell for around $25US each. The change over relay goes for $12, and the turn signal relay is $53.
For comparison, a standard 'Bosch' relay goes for around $5.
